Oil Pan And Gasket?
Old Jul 30, 2003 | 08:59 AM
RotiEatter's Avatar
Ditto
Default Oil Pan And Gasket?
I got a new oil pan and gasket and I was wondering which side of the gasket goes to the block and which goes to the pan itself. The flat side and the side with the raised edges? I searched. I was also wondering if I need any sealant. I searched and saw that some people said around the 2 bends, but if someone could be more specific I would really appreciate it. TIA. By the way this is for my 1992 B18A.
Old Jul 30, 2003 | 09:19 AM
Rywire's Avatar
Default Re: Oil Pan And Gasket? (RotiEatter)
I could be wrong, but cant you only put it on 1 way, due to the bends in it? I believe its flat side touching pan, ribbed side on block. Ryan
Old Jul 30, 2003 | 09:29 AM
JCracer723's Avatar
Default Re: Oil Pan And Gasket? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I could be wrong, but cant you only put it on 1 way, due to the bends in it? I believe its flat side touching pan, ribbed side on block. Ryan</TD></TR></TABLE>
agree
Old Jul 30, 2003 | 09:32 AM
keithv's Avatar
Default Re: Oil Pan And Gasket? (JCracer723)
D series can only go on 1 way, but i am pretty sure B series have a totally flat oil pan surface.
i think (kind of guessing here) the flatter part goes to the block and the side with ridges goes to the oil pan.
Old Jul 30, 2003 | 09:47 AM
RotiEatter's Avatar
Ditto
Default Re: Oil Pan And Gasket? (keithv)
Ok thanks guys, anyone have any advice for me on the sealant?
Old Jul 30, 2003 | 10:02 AM
TAG's Avatar
TAG
I just finished changing the pan out on my 91 CRX Si/ZC for my turbo setup. It was my first time, so I just learned all the things you are discovering now.
- For the D-series oilpans, the gasket can only go one way. If you take it out of the package, the gasket *should* have 2 natural half-circles which are pre-molded and want to bend a certain direction. Thus it's easy to see how this will mate up to your pan.
- For gasket sealant, you should get Hondabond (from Honda dealer) or Permatex Ultra-Grey (any auto store). They are pretty much the same thing. You just want to put some sealant on the "half-circle" areas. Don't go crazy putting it all around.
Then, after you bolt your pan back up to the block, wait 24 hours before refilling with oil. Not going off of experience here, but I keep reading this suggestion whenever I search for oilpan changing instructions. Seems to make sense though..I'm thinking you want to achieve a good seal (and have everything dried) before you potentially immerse your seal/gasket with oil.
Good luck.
If you want more info then what I've provided, do a search in the FI forum for "oilpan". Especially under archived content. You'll find tons.
Yeti Smasher
Honda Civic (2001 - 2005)
Mar 28, 2013 05:51 PM
Kronn 98SH
Mar 25, 2009 12:40 PM
red02s2k
Jul 19, 2007 08:02 PM
trooper0641
14
Oct 11, 2005 07:11 PM
mf RENO
Aug 31, 2004 11:06 AM
