WTB: ARP Headstuds for GSR (b20vtec), 84mm Pistons 11.0:1/11.5:1 comp,NICE CAMS (and valvetrain if n
Trying to get my b20vtec some compression + some cam + some engine management
Need:
11.0:1/11.5:1 compression 84mm pistons
p28 ecu + hondata s100 + conversion harness
nice cams + valvetrain (if they are that wild)
and some ARP head studs
Goal: 13's on street tires
lemme know whacha got!
thanks,
mike
Need:
thanks,
mike
i have je b20 pistons. 10:5:1 final compression using b16 vtec head. with pins/rings seals. eagle rods....acl LS crank bearings. and b18c arp headstuds..ALL NEW in box. e-mail me an offer:
Si00civic@aol.com
Si00civic@aol.com
im currently considering selling this setup...if the offer is good, i think i'll let it go...let me know if interested. here is what i have:
- IB/Wiseco Spec 84mm 11.8:1 c/r pistons w/rings (12:1 c/r w/b18c head)
brand new - had them installed in my sleeved 84mm b18c block, but i havent put the setup together or in a car...so 0 miles on these. it's just been sitting in my basement for months. pistons are currently on eagle gsr rods but i can take them off.
- P72 (obd1 gsr) ecu - yoshio/godspeed chipped
- Toda Spec B Cams - 15k miles - great condition - lobes look great w/Skunk2 Adj Cam Gears (i can take the cam gears off)
- Power Enterprise Super Strong Timing Belt (for b18c tho)
- Portflow PnP'd b18c1 head - ITR valves, Portflow titanium retainers, Portflow/ITR valve springs - good past 9k rpm
- b18c1 ARP head studs - brand new - never used - dunno if these would work for you with the b20 block
i have other random goodies as well.
considering selling because money flow changed.
thanks
thanks
kart_driver
26
Aug 31, 2010 01:07 PM
