Anyone know which readily available belt will work with a CTR N1 Crank pulley?
Old Jul 30, 2003 | 05:27 AM
MattD@Stoptech's Avatar
Default Anyone know which readily available belt will work with a CTR N1 Crank pulley?
A part number or description of a belt that could be picked up at an auto store would be very helpfull...
Matt
Old Jul 30, 2003 | 05:49 AM
Willard's Avatar
Default Re: Anyone know which readily available belt will work with a CTR N1 Crank pulley? (El Pollo Diablo)
hit up xr4racer... he was suppose to put the info up a while back.
Old Jul 30, 2003 | 08:22 AM
JustLooking's Avatar
Default Re: Anyone know which readily available belt will work with a CTR N1 Crank pulley? (Willard)
Hi,
Here is the size belt you need. 4PK 755
4PK stands for 4 ribbed
755 is 755mm
I hope that helps.
Old Jul 30, 2003 | 09:05 AM
Default Re: Anyone know which readily available belt will work with a CTR N1 Crank pulley? (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
They're all the same length?</TD></TR></TABLE>
George, I would assume the 755mm dimension = length (diameter) of the belt...
Otherwise that's one hell of a width
Thanks guys, I'll look for that belt!
Old Jul 30, 2003 | 09:13 AM
sackdz's Avatar
FYI if you're using an underdrive pulley on the alternator, along with the CTR pulley, the belt is the same size as stock.
Old Jul 30, 2003 | 09:36 AM
Default Re: Anyone know which readily available belt will work with a CTR N1 Crank pulley? (sackdz)
But then I wouldn't have enough juice to hear the stereo thumpin'!!!!!!!
Blk00EJ8
Apr 12, 2008 05:44 PM
sa90eg
Mar 22, 2005 08:34 PM
B18C5-EH2
Sep 6, 2004 11:59 AM
SC0TT
Oct 17, 2003 02:16 PM
oldbeefcake
Sep 10, 2003 12:34 PM
