DX TPS on a ZC?
Old Jul 30, 2003 | 04:59 AM
90CRX's Avatar
Default DX TPS on a ZC?
Will the DX TPS mount directly to the ZC without wiring modification? Somewhere during my search I saw the DX wiring needed to be reversed, although I could've sworn that was for another part.
Old Jul 30, 2003 | 06:51 AM
zCivic's Avatar
Default Re: DX TPS on a ZC? (1slickcrx)
I tried it on a B16 (which all MPFI use the same TPS). I couldn't get it to work at all. I tried swaping the green/white and yellow/white wires and tried them normally and I had no luck. I had an xtra TPS and plugged it in and it worked perfect. The DX I got set to .5 volts at closed throttle adn 4.5 volts WOT but it would still throw a CEL as soon as the car started.
Old Jul 30, 2003 | 08:02 AM
FourthGenHatch's Avatar
No because the DPFI ones work the reverse direction the MPFI ones do.
Old Jul 30, 2003 | 09:26 AM
CRXRageD's Avatar
Won't fit, the dx ts is also angled differently and won't bolt up correctly. I know cuz I tried when I first started working on Hondas.
Old Jul 30, 2003 | 02:56 PM
90CRX's Avatar
Thanks for your help and experience to back it up. Guess it's off to the junkyards for me. Good thing I'm trying to research before I actually do the install.
Tippyman
Feb 8, 2006 03:32 PM
gutted-dx
Jan 10, 2005 11:05 AM
Digitalcivic
13
Jan 1, 2003 11:13 AM
.ShawnD.
May 7, 2002 04:43 AM
