jdm itr exhaust fits a gsr???
Old Aug 6, 2001 | 02:55 PM
brwnrice's Avatar
Default jdm itr exhaust fits a gsr???
a guy told me that the jdm itr exhaust fits a gsr? is this true?
Old Aug 6, 2001 | 03:43 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: jdm itr exhaust fits a gsr??? (brwnrice)
Yes, you just need to have the B-pipe modified to fit. Any muffler shop can do this.
Old Aug 6, 2001 | 07:09 PM
TypeC's Avatar
Default Re: jdm itr exhaust fits a gsr??? (B18C-EJ1)
extend the B-pipe 4" and you're set. -C
Old Aug 6, 2001 | 09:02 PM
brwnrice's Avatar
no modifying. a jdm itr exhaust bolts on directly to a gsr. a guy from jdmhondaparts.com have a jdm itr exhaust in his gsr, and he didnt even modify it. he told me that he compared his gsr exhaust to a jdm itr exhaust and the dimentions are the same.
Old Aug 6, 2001 | 09:04 PM
B18C-EJ1
Guest
Posts: n/a
JDM ITR exhaust and USDM ITR exhaust = Same.
Old Aug 6, 2001 | 09:31 PM
Chris's Avatar
Not exactly true. JDM header and CAT are different size (diameter of openings, and length). B-Pipe is the same except for the 2.5" opening, as long as we are talking about 2 door cars.
When used together (header and CAT) they will fit to the USDM B-Pipe (but will not have the same diameter opening).
Old Aug 6, 2001 | 10:24 PM
Rhetoric's Avatar
Default Re: jdm itr exhaust fits a gsr??? (Chris)
Im using a jdm r muffler on my gsr. I didnt have to modify anything? I've never compared the jdm against us itr muffler. Although I heard the jdm piping is bigger? I dont know.
Old Aug 6, 2001 | 10:26 PM
Chris's Avatar
Default Re: jdm itr exhaust fits a gsr??? (G S R)
maybe the B-pipe dia. is the same (that would mean the Muffler is the same too).
All I know is the four door is different.
Old Aug 7, 2001 | 12:41 AM
B18C-EJ1
Guest
Posts: n/a
Realllllyyyyy.
When was the last time you saw a 4dr R?
Have any of you ever check the part # between a JDM ITR cat back and a USDM ITR cat back???
You've been had by the JDM hype.
Old Aug 7, 2001 | 06:16 AM
H23 Power's Avatar
i think it will only bolt directly to the 00+ GSR which i think the CAT was moved and the USDM ITR exhaust bolts directly on...which should mean the JDM one does also
Old Aug 7, 2001 | 08:14 AM
TypeC's Avatar
Default Re: jdm itr exhaust fits a gsr??? (01GSR)
Not really. Assuming it's the same length as the US ITR one, then it is 4 inches too short. I actually have it on my gsr.
all the time in japan.
yes and no. The 94-99 GSR's have a shorter header which is why the exhaust doesn't reach, the 00+ gsr use a USDM ITR header (you bastards!) so it bolts directly. the cat length is the same.
Old Aug 7, 2001 | 08:21 AM
Go Mifune's Avatar
New User
yeah, i have a jdm honda radio, but it doesn't seem to work
but seriously, i will never understand why anyone would buy an itr muffler for their gsr, jdm, usdm, european whatever...
Old Aug 7, 2001 | 08:25 AM
TypeC's Avatar
Default Re: jdm itr exhaust fits a gsr??? (Go Mifune)
OK, I'll school you then. The ITR exhaust is 2.25" all stainless steeal mandrel bent exhaust. Most aftermarket exhaust aren't even stainless, but as 2.25." The best thing about it is that is is very QUIET and looks stock (sleeper effect). My car ran 3 tenths faster with it.
Also, the opening flange of the B-pipe is actually about 2" (same size of the cat), but I replaced it with a 2.25" flange. HTH, -C
Old Aug 7, 2001 | 08:44 AM
Go Mifune's Avatar
New User
Default Re: jdm itr exhaust fits a gsr??? (TypeC)
thank you (i was hoping you'd answer). i did not know several of those facts (but i do know you are the sleeper king )
Old Aug 7, 2001 | 10:29 PM
B18C-EJ1
Guest
Posts: n/a
Really?? I'd love to see one. You got any pics????
Old Aug 7, 2001 | 10:38 PM
Chris's Avatar
There everywhere...search the net.
Old Aug 7, 2001 | 10:42 PM
B18C-EJ1
Guest
Posts: n/a
Man, I've see all kinds of cars, but I've never seen a 4dr ITR from Japan.
It's not that I doubt you, but I'd love to see one.
Send me a link or something.
Old Aug 8, 2001 | 03:54 AM
Asahi's Avatar
Type-C is right the lengths of the 94-99 Integras are different than the Type-R and 2000-2001 Integras. THe 94-99's had a longer B pipe. My understanding is the JDM setup is the same as the 2000-2001 and Type-R setup.
Mike at IPS is a good source for this info.
yoda888
Jan 12, 2004 11:28 PM
gorilla nasty
Apr 15, 2003 07:45 PM
ebelp
May 6, 2002 08:12 PM
jteasy
Aug 10, 2001 04:43 PM
