Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
help with mounting Takata harnesses and autopower rollbar
Old Jul 29, 2003 | 08:51 PM
BlueR's Avatar
Default help with mounting Takata harnesses and autopower rollbar
https://honda-tech.com/zerothread?id=577125
any help would be much appreciated
Old Jul 30, 2003 | 03:23 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: help with mounting Takata harnesses and autopower rollbar (BlueR)
marc, that is a bad design. we could drill the autopower for the eyebolts , but i'd rather install a set of sparco/trw sabelts.
Old Jul 30, 2003 | 04:34 AM
Knestis's Avatar
Pictures of the parts in question would help. If you do have to bolt to the cage structure, the best way to do it is drill a hole all the way through the tube, large enough to put a new piece of steel tube through it - with an ID the appropriate size for a bolt. Weld the new tube into the hole, long enough that it just clears the rollcage tube and use a GOOD bolt - none of this Home Despot grade 5/8 crap - through the eye. (Don't know if you have eyes or clips.) Another answer is to weld tabs onto the cage. NOTE however that the shorter the harnesses are, the less stretch you get in a crash. This can be either GOOD or BAD depending on whether you are talking about attenuating the impact's effect on your bod' or travelling far enough to hit the dash/steering wheel...
Kirk
thrty8street
34
Jun 28, 2004 07:06 AM
pburke23
Jun 5, 2004 09:14 AM
sohc00
Mar 22, 2004 05:15 AM
sjteg
Jan 29, 2004 11:57 AM
Blowensi
Jul 9, 2003 08:38 PM
