Head Gasket/Pistons
Old Aug 6, 2001 | 01:56 PM
TypeR1558's Avatar
New User
Default Head Gasket/Pistons
All,
Could someone educate me... why are pistons better than a headgasket for lowering the compression? Is it risky to use a head gasket for lowering compression (for turbo applications)?
Thanks,
Jon
Old Aug 7, 2001 | 11:06 AM
ZygSpeed's Avatar
Default Re: Head Gasket/Pistons (TypeR1558)
You can only do so much with a head gasket (maybe drops compression 0.4 or so), whereas with replacement pistons a turbo-pleasing 9:1 is easily obtained (vs. maybe 10.2 : 1 with only a gasket change, the gasket being about twice normal thickness).
The reason people opt for just doing the head gasket only, is that it's MUCH cheaper than having to re-do a block for fresh pistons and rods.
Old Aug 7, 2001 | 12:46 PM
FAST94GSR's Avatar
New User
Default Re: Head Gasket/Pistons (zygspeed)
stock pistons arent' forged and can't hold the boost.
Old Aug 7, 2001 | 12:55 PM
ZygSpeed's Avatar
Default Re: Head Gasket/Pistons (FAST94GSR)
Well I guess that should settle it.
Old Aug 7, 2001 | 01:51 PM
TypeR1558's Avatar
New User
heard they could hold low boost (6lbs).
jon
Old Aug 7, 2001 | 02:03 PM
EPGONZALEZ's Avatar
and also you could go with a more desirable flattop design piston..
EJ8_Man
Jun 25, 2010 10:16 AM
GhostAccord
Mar 7, 2008 10:54 AM
TRuST
Aug 29, 2002 06:32 PM
