Help on 91 hatch fuel pump
Old Jul 29, 2003 | 07:14 PM
MiChangCRX04's Avatar
Default Help on 91 hatch fuel pump
Where do I get to the fuel pump from? My friends fuel pump died and we didnt find out till after we finished his swap and tryed to start it. Pictures would help alot.
'89 CRX XSi
1 gen Integ B16a
CTR cams sooon
Old Jul 29, 2003 | 09:00 PM
Redline130's Avatar
Default Re: Help on 91 hatch fuel pump (MiChangCRX04)
To get to the fuel pump you will need to lower the fuel tank. The fuel pump is only accessible once you lower the tank. It helps if you drain the gas first. Once you lower the tank, you'll see where the pump can accessed. There will be a round cover held on with several 10mm nuts and some wiring. Undo the nuts and carefully pull out the fuel pump. All of this make take some contorting of your body as well.
cleo7
Jan 23, 2013 08:53 AM
twedter02
May 26, 2008 05:08 PM
Crimson_Tide
Jul 27, 2005 04:24 AM
