safe bore on ls vtec
For 84mm pistons you should sleeve it no matter on a ls block. Stock sleeves can only handle i believe an 82mm bore safely and anything above that needs to be sleeved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipsi266h »</TD></TR><TR><TD CLASS="quote">For 84mm pistons you should sleeve it no matter on a ls block. Stock sleeves can only handle i believe an 82mm bore safely and anything above that needs to be sleeved.</TD></TR></TABLE>
i second that
i second that
nickgmiller04
12
Mar 26, 2004 04:07 PM
