How can tell 1g DSM BOV is crushed?
Old Jul 29, 2003 | 05:03 PM
reignofchaos's Avatar
Default How can tell 1g DSM BOV is crushed?
Hey i got 2 BOV, one bosch plastic one and 1G DSM BOV, the DSM one is harder to push open than the bosch one.. just wondering how can i tell if the 1g is CRUSHED?
Old Jul 29, 2003 | 05:17 PM
Jared's Avatar
Default Re: How can tell 1g DSM BOV is crushed? (reignofchaos)
All the 1gs are harder to open than those plastic ones anway, but after I crushed mine, I couldn't tell a physical difference.
Old Jul 29, 2003 | 05:22 PM
ffgeon's Avatar
Default Re: How can tell 1g DSM BOV is crushed? (Jared)
when i used a crushed dsm valve on my car, it wouldnt open. (im running real low boost right now), but when i switched to an uncrushed one, it worked wonderful. you can tell if its crushed by the top of the valve. you put it in the vise, the mounting flange on one jaw and the green (i think, im color blind) in the other jaw, then sqeeze the poo out of it. ill tell javier to bring his camera to shop tonight and ill take a pica for ya. unless someone elst has some photos?
Old Jul 29, 2003 | 05:28 PM
Full-Race Geoff's Avatar
Default Re: How can tell 1g DSM BOV is crushed? (ffgeon)
jon... you got a little bit carried away with the crushing. The crush only needs to be a little bit, i think you tried to close the vice completely...
Old Jul 29, 2003 | 05:35 PM
Full-Race Javier's Avatar
those bosch plastic "diverter valves" are a POS. they begin to leak after 9psi IIRC......at least they did on the supercharged NSX's
Old Jul 29, 2003 | 06:00 PM
Jared's Avatar
Default Re: How can tell 1g DSM BOV is crushed? (javierb14)
To do it right you really need to do it in a hydraulic press so it goes slow and use a vacuum pump to check where it opens.
Old Jul 29, 2003 | 06:26 PM
2000vsm's Avatar
but the question of this gentlement still hasn't been answered.
How can you TELL by looking, if it's crushed?
How much are these DSM ones' suppose to open at anyways? like what apps, 8psi 12psi?
Old Jul 29, 2003 | 06:53 PM
falcongsr's Avatar
What is this crap?
Default Re: How can tell 1g DSM BOV is crushed? (2000vsm)
if its been REALLY crushed then the gren top part which is a smaller cylinder than the body of the BOV is sunk in slightly.
i most people dont need to crush these BOVs for under 10psi. the DSM guys started crushing them so they wouldnt leak at high boost.
Old Jul 29, 2003 | 07:08 PM
Burke's Avatar
Banned
Default Re: How can tell 1g DSM BOV is crushed? (NOT EVIL falconGSR)
i got one and plan on running 10-12 psi - should i crush mine?? if so, how do i do it right????
Thanks
Old Jul 29, 2003 | 07:12 PM
92HB_HB's Avatar
Default Re: How can tell 1g DSM BOV is crushed? (Burke)
someone should jsut post a pic of a crushed one next to an uncrushed one ... how about that?? b/c i'm interested in seeing it too
Old Jul 29, 2003 | 07:30 PM
lazerus's Avatar
Default Re: How can tell 1g DSM BOV is crushed? (92HB_HB)
looking at the base of the vac nipple there is a larger circumference part of the BOV on the left (see pic) if that base of the nipple is closer than this pic, or touching it, then it is crushed.
Old Jul 29, 2003 | 10:12 PM
Default Re: How can tell 1g DSM BOV is crushed? (lazerus)
what do you mean, the BOTTOM of the green part is lower than the top of the silver????
Old Jul 29, 2003 | 10:38 PM
lazerus's Avatar
let me say it slower.
l o o k i n g a t t h e b a s e o f t h e v a c u u m n i p p l e t h e r e i s a l a r g e r c i r c u m f e r e n c e p a r t o f t h e B O V o n t h e l e f t ( s e e p i c ) i f t h a t b a s e o f t h e n i p p l e i s c l o s e r t h a n t h i s p i c , o r t o u c h i n g i t , t h e n i t i s c r u s h e d .
O n l y t h e t o p s e c t i o n o f t h e b o v w i l l " c r u s h " t h e s e c t i o n w i t h t h e v a c u u m n i p p l e o n i t .
Lol
Only the green top part (with the vacuum nipple on it) will crush down some.
Old Jul 30, 2003 | 04:54 PM
15psi of fun's Avatar
It will have a dent in the top where the red circle is
Old Jul 30, 2003 | 04:59 PM
falcongsr's Avatar
What is this crap?
Default Re: How can tell 1g DSM BOV is crushed? (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">It will have a dent in the top where the red circle is
not just a dent, but that whole area circled will sit lower in the BOV. the vacuum nipple will actually be closer to the bottom of the BOV almost to the point where its hard to slide a vacuum line on it fully. the spring is around the circumference of the red circle there. so denting the middle wouldnt do anything. the whole thing goes down when you crush it.
Old Jul 30, 2003 | 05:01 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">i got one and plan on running 10-12 psi - should i crush mine?? if so, how do i do it right????
Thanks </TD></TR></TABLE>
dont do anything unless you find out BOV is leaking boost.
Old Jul 30, 2003 | 07:32 PM
He just asked how he can tell I know there is more to it then just a dent I was just giving him the idea of what it would look like. I have found about 20 web sites on how to do it if I was going to do this mod I would read up on it first.
Old Jul 30, 2003 | 07:37 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">He just asked how he can tell I know there is more to it then just a dent I was just giving him the idea of what it would look like.</TD></TR></TABLE>
and i corrected you cause it doesnt look anything like a dent when "crushed" correctly.
Broertje
Mar 2, 2012 10:52 AM
wernhersey
Dec 5, 2007 09:58 AM
d16tuner
Apr 23, 2004 01:26 PM
fire7882
Nov 25, 2002 11:07 PM
