gear grindin when i put it in rev.
everytime i try to put my car in reverse, the gears grind.....and then it just kinda slips in.....is there something wrong with my flywheel or clutchplate? does anyone else's eg do this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomo »</TD></TR><TR><TD CLASS="quote"> The syncros have to have to to move backwards.</TD></TR></TABLE>
Make sure youre not rolling at all and just wait a half a second longer than you normally would.
With all Hondas, there's usually a slight *crunch* when put in reverse.
If it's a serious grind, try coming to a complete stop before putting it in reverse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsi »</TD></TR><TR><TD CLASS="quote">everytime i try to put my car in reverse, the gears grind.....and then it just kinda slips in.....is there something wrong with my flywheel or clutchplate? does anyone else's eg do this?</TD></TR></TABLE>
before putting it in reverse....throw it in first or second first..then reverse...
dont remember the reason, but just do that first...it should go into reverse easily...
i haven't grinded my reverse ever...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">before putting it in reverse....throw it in first or second first..then reverse...
i haven't grinded my reverse ever...</TD></TR></TABLE>
Yes, you're supposed to come to a complete stop (which stops the output shaft of the transmission), and slip it into a forward gear before selecting reverse (which stops the input shaft). This way, both shafts have stopped moving and it will not grind when the gears mesh.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">i just put it in 4th, then R to alleviate the problem. </TD></TR></TABLE>
Thats what i do
Thats what i do
yep. you're suppost to do that to all honda cars.
