max power with 550s
What is the max power i can make with 550 CC injectors. I have a walbro 255, and custom fuel setup with aeromotive FPR. So i can adjust the fuel pressure. Some numbers from your setups would be nice.
people are gona tell you to check out the rc engineering website. But id like to know to, from peoples experiance and what managment they used. civcexcoupeblack what type are you gona use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyQuiL »</TD></TR><TR><TD CLASS="quote">people are gona tell you to check out the rc engineering website. But id like to know to, from peoples experiance and what managment they used. civcexcoupeblack what type are you gona use?</TD></TR></TABLE>
hehe yep. http://www.rceng.com/technical.htm
so lets see...60psi of fuel pressure and an injector duty of 85%. Thats around 350hp and should beable to run that safely. Anymore injector duty and your pushing the injectors pretty hard.
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku »</TD></TR><TR><TD CLASS="quote">Doug from hondata said that 550cc saturated injectors should be very safe for 320-350 hp as long as you have enough fuel pressure to back them up with.
its amazing how accurate the rc injector tech pages are
liam
liam
I bought 550's from viren. I forget the brand, but they are saturated. I installed them last night...along with my fuel setup, and managment (uberchip). Everything seems good.
koczeka
Oct 30, 2008 08:52 AM
