I NEED HELP FIXIG MY CAR
Old Jul 29, 2003 | 11:52 AM
brnojoke's Avatar
Default I NEED HELP FIXIG MY CAR
Hey everybody,
i have an 88 hatch with an 89 d16a6 swap in it. everything with the swap went smooth but now i went to start it after everything was wired up and my main relay assembly is ticking and my ecu is throwing a dot in rythm with the ticking. what the hell does that mean, and how do i fix it? thanks to all, br
Old Jul 29, 2003 | 12:17 PM
4drEF's Avatar
Keyboard Humorist
Default Re: I NEED HELP FIXIG MY CAR (brnojoke)
Maybe it's your main relay?
The main relay does two things. It provides power to the fuel pump and power to the ECU. Maybe the portion of the relay that gives power to the ECU is going bad.
Old Jul 30, 2003 | 07:09 AM
brnojoke's Avatar
i got it resodered and it didnt work.
Old Jul 30, 2003 | 08:18 AM
FourthGenHatch's Avatar
Default Re: (brnojoke)
Check your distributor wiring. There are 2 white wires on the dist plug. Switch them and see if it fires up.
Old Jul 30, 2003 | 09:34 AM
bagged89hatch's Avatar
Default Re: (FourthGenHatch)
this may sound stupid but is it even cranking over. if its not cranking and the relay is clicking then it may be a dead battery
Calundeen
May 20, 2019 08:02 AM
Serdar
Apr 13, 2014 09:34 AM
JAlvarez
23
Feb 9, 2011 10:18 AM
tragiclude875
Mar 26, 2007 06:00 PM
FunIntegras
Sep 1, 2005 08:04 AM
