respectable 1/8 mile times?
You you ran a 15.99 on the 1/4. your 1/8 should be 10.25. If you ran a 15.0 1/4, then you would run about 9.6 1/8. That should help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xvracing »</TD></TR><TR><TD CLASS="quote">You you ran a 15.99 on the 1/4. your 1/8 should be 10.25. If you ran a 15.0 1/4, then you would run about 9.6 1/8. That should help you.</TD></TR></TABLE>
9.6 eighth = 15.0? I don't think so. Try like a 14.7. (look at my sig, that 9.6 was with a horrible launch too.)
I have a CRX HF with a B18A1 swap and I/H/E. My best time in the 1/8 is 9.78 at 73 mph on crappy 'camber-worn' street tires. I'm gonna buy some slicks soon, so hopefully I can get a 9.2-9.3 out of her.
i went just the other day and ran a 9.83 at 69.89 mph stock si motor i/h/e and it was 40 degrees hotter than when i ran a 9.8 and i didnt have the header yet.
