new and used parts 4sale...
ZEX smart nitrous kit. $490
Greddy Full Auto Turbo Timer. $89
Greddy Type-S Blow-off valve. $199
STR pro series camgears(B-series). $150
MSD timing controller (Timing advance) for NA cars. $125
MEZIERE Elec Water Pump Kit !!!BrandNew!!! (5+HP gains from 0 to max RPM) B-Series VTEC Kit. $300
1st Gen OBD0 B16 SPOON ECU $350
95 GSR Crank $100
94 GSR OEM Flywheel $75
99 Si OEM Flywheel $75
98 GSR ecu 37820-P72-A04 $200
Stock LS clutch not even broken in yet. mint. $100
95 Del-Sol B16 DOHC VTEC ECU with JET chip $350 Excellent chip for NA cars running bolt-ons.
96+ LS Bottom End disassembled and inspected, ready to be built. $300. Aftermarket parts and assembly available for an extra charge.
94-95 LS front suspension. Complete with crossmember. $make offer. pick-up only.
GSR OEM Valves excellent condition, no damage $5each (vs. $16new)
AIR BAG Sets from 95 GSR's. Black Set, Charcoal Set. $100per set
95 GSR Rods 50K. Perfect Condition $50
94 B16 Rods 40K Perfect condition $50
98 GSR Power Steering Pump (this pump is needed for 6g B-series Hybrids) only14K $100
94+ Integra Full Size Dual Core Radiator Mint, less than 1000miles and comes with both fans. $125
94 B16 Crank Mint $125 add $40 for professionally micro polishing bearing surfaces
94 B16 Stock Exhaust valves $5ea(vs $16ea new)
92 Accord EX 5spd ECU 37820-PT6-A12 $125
98 Prelude Alternator 20k w/Unorthodox underdrive pulley. $125
96 Accord VTEC Distributor 48K. $125
97 F22b1 SOHC VTEC 40k. Longblock ONLY. NO tranny or ECU. $350
OEM 97 Prelude Axles ??mileage but in excellent condition. Very tight. $150
H23 Crank Mint $150 add: $40 for professionally micro polished bearing surfaces
92-95 Si Stock Exhaust valves $5ea (vs $16ea new)
92-95 CX Altrernator $75
92-95 CX Distributor $100
92-95 CX idle air control valve $20
92-95 Dseries flywheel $75
92 CX ecu P05 $100
91 Si ECU $100
91 Si Distributer $100
91 Si Alternator $65
91 Si Complete intake manifold $65
92-95 Si Starter $50
95 GSR Crank $100
92 CX ecu P05 $100
91 Si ECU $100
