DOHC ZC build OPINIONS...
Old Jul 29, 2003 | 08:20 AM
SloCivicHMM's Avatar
Default DOHC ZC build OPINIONS...
I wanna boost my ZC....and in my head I have this...to "build the block on a budget"
DOHC ZC:
VX rods or use LS rods (gotta notch the block)
a6 pistons (not sure on pistons yet)
mill head .3mm
y8 metal HG
Balance the crank, UR Crank Pulley, 13lbs Flywheel (stock lightened)
would this hold up 7lbs easy?? I'm looking for 10.2:1 final compression , boosting on DIY turbo kit. Bare with me I'm still learning, I know about fuel and stuff still looking stuff up.
FUEL: Lude 340 injectors, 255 fuel pump, Fuel controler (HKS or Apex)
Reason I don't go for DSM injectors is that iwas told to stay away from them and LUDE are cheaper...haha
Opinions are great guys, hook me up, I'm looking to start buying all these parts to boost by December, maybe later if I get into NASA this fall.
-Jose
Old Jul 29, 2003 | 08:36 AM
DJ_SaNdOz's Avatar
Default Re: DOHC ZC build OPINIONS... (SlowCivicHmm)
http://www.knology.net/~jediklc/D.htm
That may help some w/ CR & stuff. As far as the pistons, you will need some high CR pistons for teh A6 in order to get the CR you are looking for. You may also want to look into getting the LS valve train put in for some security for those high revs that you'll want w/ a boosted ZC. There was a post about the valve train a few weeks ago. You could also go all custom w/ teh valve train- you can view all of the necessary specs in KeithV's sig. I am not definatievly positive on the amount of work needed for the rods and stoff. g/l, let us know how it comes out.
Old Jul 29, 2003 | 08:53 AM
Default Re: DOHC ZC build OPINIONS... (DJ_SaNdOz)
I'll still be reving to the stock rev limit, but better safe than sorry right!!
THanks for the link, but I'm not sure on the piston to deck height and check valve clearance.....this is my first project.....and daily driver so...haha help would be nice...
I did put everything OEM ZC with 2 layer head gasket and it gave me 10.0xxx: 1 compression not sure how the clearance and deck height numbers t hough...
Old Jul 29, 2003 | 11:35 AM
Davep's Avatar
In my opinion if your engine runs good to start with that's a waste of time.
A stock block ZC will handle 7 psi without any problems.
I drove a stock block zc with greddy kit boosting 7-8psi for over a year.
Old Jul 29, 2003 | 11:37 AM
Default Re: DOHC ZC build OPINIONS... (Davep)
Very true, but I want the option to up the boost if I wanted too.....just being **** sorry...
Old Jul 29, 2003 | 11:58 AM
LoSt is BlaCk's Avatar
notch the block for ls rods, also have then shot-peened, it will help also. why do you want the 10 to 1 compression, with boost you should go low so that you can play with boost a little more, you may loose some out of boost performance but it will allow you to boost a bit more.
Old Jul 29, 2003 | 02:05 PM
nikitad's Avatar
Default Re: DOHC ZC build OPINIONS... (Chpt1onBOOST)
Don't you have to notch the block for b16 rods, but not for b18 ones?
BTW y8 headgasket is not a match for a DOHC zc. Compare the two gaskets - they are different.
Old Jul 29, 2003 | 05:29 PM
Default Re: DOHC ZC build OPINIONS... (nikitad)
Nah I read any b series rods you have to notch the block..
Thanks for the info on the head gasket...any clue what HG I can use??
Old Jul 29, 2003 | 05:54 PM
slywfbpsi's Avatar
hks makes two types of head gaskets for the zc, bead and gommet, the bead gives you a 9.9 c/r and the gommet gives you a 10.0 c/t both go for about $117 from takakaira.com.
Old Jul 30, 2003 | 07:45 AM
Default Re: DOHC ZC build OPINIONS... (slywfbpsi)
Thanks HOMIE!!!
Old Jul 30, 2003 | 10:11 AM
slywfbpsi's Avatar
no problemo
Old Jul 30, 2003 | 10:15 AM
99EKhatch's Avatar
web cams are excelent in a zc....350 shipped i believe
Old Jul 30, 2003 | 10:35 AM
Default Re: DOHC ZC build OPINIONS... (99EKhatch)
I have a spare set of stock cams to get reground......that a good idea...crowwer does em but I heard they brake......
web cams does regrinds too.....opinions??
This is a budget build that should be realiable...I'm not looking for low 12's...just power in general!!!
Old Jul 30, 2003 | 11:25 AM
slywfbpsi's Avatar
webcams doesn't make boost application for the zc only n/a and drag. hks is the only one with a billet boost application (not regrind), ef-1 also makes cams for the zc but their boost applications is only for a high hp zc application.
Old Jul 30, 2003 | 12:21 PM
HMMMMM...HKS is $$$$ I might just do the Crower to whatever spec you'd like or what t hey recommend....cams will be later.....for now I need to know what pistons I can use.....
Stock LS rods shotpeened is what I'm going to use....what pistons would you recommend on a budget??
Old Jul 30, 2003 | 01:42 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">I have a spare set of stock cams to get reground......that a good idea...crowwer does em but I heard they brake......
This is a budget build that should be realiable...I'm not looking for low 12's...just power in general!!!</TD></TR></TABLE>
IM exospeed- they have very good prices on regrinds (so low that I will let Wil tell you) & they may have a boost application for your needs. They have a pretty good rep- that's who I will be going to for my cam regrinds.
Old Jul 30, 2003 | 01:52 PM
yeah I've talked to Wil before....he had no spare cams for a zc laying around...I'll have to hit him up now that I have spare cams...
http://www.exospeed.com
Anyone know about the 1jz pistons with b16a rods??
Old Jul 31, 2003 | 01:54 AM
90CRX's Avatar
Anyone know about the 1jz pistons with b16a rods??</TD></TR></TABLE>
I'm pretty sure there was a post in the archived section regarding this. It's a locked post now but it had a lot of information you could use. good luck
Old Jul 31, 2003 | 07:50 AM
Default Re: DOHC ZC build OPINIONS... (90CRX)
Found the t hread but with the stock ZC compression being 9.5:1 with the GTE pistons my compression would be 7.5:1......**** that...too low...hahaha...
Any ideas what OEM piston I can use??
Old Jul 31, 2003 | 08:57 AM
slywfbpsi's Avatar
they're aren't any OEM pistons to use that won't give you a 8.5 to 9.5 compression. you would have to go aftermarket: endyne, je, or custom.
Old Jul 31, 2003 | 10:06 AM
well stock compression is 9.5: 1 right??? I'm willing to go 8.5:1 thats not bad for daily driving....I just want something more reliable than the zc pistons......that will hold the boost more...
I'm just learning so thanks for the help........I can always mill the head a lil bit and use a diff head gasket to get my compresion to 9:1 for a good area for booost, LS rods/ some OEM piston.....right??
Old Jul 31, 2003 | 11:51 AM
slywfbpsi's Avatar
yes the stock compression is 9.5, but there is NO OEM piston that would give you an 8.5 compression, you are stuck with aftermarket - endyn 8.5, or je 9.2, or custom. all OEM pistons besides a zc piston will put you around the 7.6 c/r. HKS makes two different head gaskets for the zc, that would bump your compression to .4 or .5 points, so if you went with endyn, your c/r would be around 8.9 to 9.0, or je 9.6 to 9.7. You are going to have to spend money on aftermarket piston not OEM if you want more than 200whp, on a daily driven basis.
Old Jul 31, 2003 | 12:12 PM
damn and I wanted to keep this cheap....cuz this is my learning motor..haha....
would I be fine with bigger rods and the stock pistons?? I'm going to run 7lbs on the block but want to be able to go bigger if I need to and have the boosted motor last me a good while....
Old Jul 31, 2003 | 12:25 PM
slywfbpsi's Avatar
What are your goals? Are you looking for 200whp? then you can keep the block stock, get a headgasket if you want to. 350-400whp? you're going to have to get aftermarket pistons and rods, then sleeving, the list goes on and on. 7 lbs is fine, if you are running a small turbo, 14g, 16g, 18g, t25, t28, t3, but 7 psi on a t3/t04e, t3/60-1, sc61, sc50 and you're going to be looking at more than 200whp.
Old Jul 31, 2003 | 02:05 PM
my goals are not 1/4 mile times....or crazy amounts of power......
I want to learn and not blow up my daily driven hatch......I'm just trying to go the boost route to learn a bit, the zc is not that great but way better than my vx motor Ihad stock..haha......
7lbs will be run a toyo 1jz stock turbo......whatever that is... a friend is helpin gme build the manifold and stuff.....
