Tightening Alternator belt
Old Aug 6, 2001 | 09:11 AM
98TypeR's Avatar
Default Tightening Alternator belt
Whats the easiest way to tighten this belt. Mine has come loose and is sqealing like a little girl. How do i get enough force to get this tight?
Old Jan 31, 2004 | 01:16 PM
yoohoo's Avatar
Default Re: Tightening Alternator belt (98TypeR)
mine was squealing at start up too, but then I changed the belt and now the sound is gone.
Old Jan 31, 2004 | 04:41 PM
markpaco's Avatar
loosen the upper nut and lower pivot nut. The lower one can be accessed easily from the wheelwell. There is an area where you can use a prybar to preload the alternator belt. It is on the top and you can see a thick flange on the alternator and an accomodating flange on the engine. I am not sure what the defection is but 3/8"-1/2" at the midpoint of the longest part of the belt is a good rule of thumb. Otherwise, check out your HELM. Then tighten the top nut and then the bottom one.
shorto85
Oct 12, 2005 01:39 PM
519[H]Si
May 25, 2004 09:25 PM
Kato7997
Feb 23, 2003 11:23 AM
