Head gasket for B18C5 / JRSC
I want to run my JRSC with 13.5 psi of boost and water injection. Therefore i need to reduce my 11:1 stock cr to something like 9:1.
How about the thickness of the head gasket i need ? 2 mm ?
Is it safe to run the JRSC at that boost level with a thicker head gasket ?
BTW: RC 440 or RC 550 for that setup ?
Thanks
Thanks
Don't do it or you will feel this pain
Jrsc's don't like that high of boost, that rpm can be bad for the blower and with that kind of heat you will be at the point of "diminishing returns". In other words you will lose horsepower. Run it at 10-11 psi and spray some nitrous on it
1badITR
Apr 21, 2002 04:05 PM
