h22 slicks
taking the eg hatch to the track. h22 with an-r header tuned cam gears intake and hondata s200.will the 22x9x13 m&h slicks be enough to have a good launch in my hatch or bigger slicks needed. realy need help deciding.
I'm currently using a 13x8x24.5 MT and love it. You have to figure with a taller slick you have higher mph and top end and you won't be shifting into 4th or 5th gear. I'm in 3rd at the end of the traps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92h22a »</TD></TR><TR><TD CLASS="quote">I'm currently using a 13x8x24.5 MT and love it. You have to figure with a taller slick you have higher mph and top end and you won't be shifting into 4th or 5th gear. I'm in 3rd at the end of the traps.
.</TD></TR></TABLE> [img]www.imagestation.com%2Fpicture%2Fsraid71%2Fp9b3fcc 7a310694f6018f9d3fc9b3a475%2Ffb9c6b5d.jpg[/img]
those are way too big for you if you're not getting into 4th...you want to be well into 4th at the end of the track. you should try a 22 inch tire
.</TD></TR></TABLE> [img]www.imagestation.com%2Fpicture%2Fsraid71%2Fp9b3fcc 7a310694f6018f9d3fc9b3a475%2Ffb9c6b5d.jpg[/img] those are way too big for you if you're not getting into 4th...you want to be well into 4th at the end of the track. you should try a 22 inch tire
look like those 24.5's are puttin a hurt on you if youre in 3rd gear at the end of the track...try something smaller and more in the line for what you need.
You just have to try different sizes out to see what suites you best. I suggest going with 22x8x13 or if your making more then 180whp try the 22x9x13. that should be fine. good luck!
fastwanabe
39
Mar 20, 2003 08:07 PM
