smoke coming from exhaust all the time?
Old Jul 28, 2003 | 09:11 PM
redline650's Avatar
Default smoke coming from exhaust all the time?
i have dc header 4-2-1, and a greddy evo exhaust..and whenever i rev it up past 4000 rmp, no matter cold or hot, white smoke always pours out of the exhaust, got the **** smogged to, or attempted, failed it bad! it backfires to sometimes...what is the problem???
Old Jul 28, 2003 | 09:14 PM
King_j's Avatar
Default Re: smoke coming from exhaust all the time? (redline650)
white smoke. are you low on coolant?
RSVTECDC4's Avatar
does your car pass smog?
Old Jul 28, 2003 | 09:15 PM
redline650's Avatar
Default Re: smoke coming from exhaust all the time? (rugratxp)
i checked the coolant and its cool....yeah i failed, wasnt even close to passing it
RSVTECDC4's Avatar
oh, you did get it smogged, sorry, didn't read all the way when i first got my car, smoke came out of my exhaust too. after i got a new clutch and a new carborator, the exhaust was fine. get your cars overheating thing checked
Old Jul 28, 2003 | 09:17 PM
King_j's Avatar
what? carbs and overheating? did you read his entire post?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rugratxp &raquo;</TD></TR><TR><TD CLASS="quote">oh, you did get it smogged, sorry, didn't read all the way when i first got my car, smoke came out of my exhaust too. after i got a new clutch and a new carborator, the exhaust was fine. get your cars overheating thing checked</TD></TR></TABLE>
Old Jul 28, 2003 | 11:56 PM
blakacintegera's Avatar
Default Re: smoke coming from exhaust all the time? (King_j)
did you take out your cat? most gsr's i see with full exhaust usually puff a little smoke. maybe your fuel mixture is a little off too.
Old Jul 29, 2003 | 02:20 AM
integrx's Avatar
New User
go to the auto store and buy that stuff you put in the gas to pass smog.
Old Jul 29, 2003 | 02:59 PM
slo2kgsr's Avatar
Default Re: smoke coming from exhaust all the time? (integrx)
White smoke is water which could be a head gasket
blue smoke is oil more then likey rings
Black smoke is feul you are running to rich
hope that helps
Old Jul 30, 2003 | 05:09 AM
wcsinx's Avatar
Hate to tell you this man, but that's burning oil you're seeing. A rich mixture would be black smoke. People always say oil smoke is blue, but to my eyes it always looks white. (though steam (coolant) is "whiter") Also coolant going through the exhaust will have kind of a sweet, nauseating smell to it. If it's happening only when you rev up, then chances are you've blown a piston ring(s). Is it actually happening when you're at 4000 RPM or only after you let off the throttle from 4000 RPM? I'd start with a compression test. I'll bet you see a low cylinder or two.
db8int3gra
Feb 11, 2009 10:07 AM
Mechman456
Honda Civic (2006 - 2015)
18
Dec 2, 2007 09:04 AM
redDAinteg
Jan 9, 2006 04:57 PM
dylokjai
Dec 30, 2004 04:53 PM
blitzteggsr
May 4, 2004 06:29 PM
