Is your turbo watercooled ?
Old Jul 28, 2003 | 08:34 PM
X2BOARD's Avatar
Default Is your turbo watercooled ?
Just wondering... I am going to use a stock Mitsu turbo that seems to be watercooled. I would very much like to take advantage of this on my daily driver... BUT...
How do you hook it up ? tap off of the coolant nipples ? What ?
Is there supposed to be high or low pressure ? etc...
Old Jul 28, 2003 | 08:36 PM
InTeGrA B18b1's Avatar
Default Re: Is your turbo watercooled ? (X2BOARD)
youve been on this board awhile im pretty sure you can search for it. you use the coolant lines under the throttle body.
Old Jul 28, 2003 | 08:37 PM
reignofchaos's Avatar
Default Re: Is your turbo watercooled ? (InTeGrA B18b1)
Which way is IN and out, cuz if you screw it up... i dunno
Old Jul 28, 2003 | 08:42 PM
Accord94DX's Avatar
Default Re: Is your turbo watercooled ? (reignofchaos)
and the turbo itself:
its easy!
Old Jul 28, 2003 | 09:17 PM
Farnsrocket's Avatar
Default Re: Is your turbo watercooled ? (Accord94DX)
I used the coolant lines from my stock oil cooler (B18C1).
Old Jul 28, 2003 | 09:37 PM
Can you circle in RED for RETURN and GREEN for SEND please!
Also what size is the coolant hose?
Old Jul 28, 2003 | 09:52 PM
lazerus's Avatar
the coolant can flow either direction, just as long as you use a high pressure coolant for feed, and low pressure for outlet.. as the TB uses-- hook them up either way they are best for you...
Old Jul 28, 2003 | 10:08 PM
X2BOARD's Avatar
Default Re: Is your turbo watercooled ? (lazerus)
Would it be better/worse to use the lines to the heater core ? Where I am... I don't need to keep it hooked up.
Old Jul 28, 2003 | 10:22 PM
LiLOtaku's Avatar
I don't mean to jack your thread, but I was wondering if on a B16 with a typer manifold, does the passage that you block off on the manifold provide enuff pressure for this application?
I was actually gonna run it like this
"xtra passage from typer manifold-->turbo-->tee into throttle body water lines(i don't run these into the throttle body anymore since I have an aftermarket one)"
Just wondering if this would work.
Old Jul 29, 2003 | 06:43 AM
X2BOARD's Avatar
Default Re: Is your turbo watercooled ? (LiLOtaku)
So how do you know which side is high, which is low (pressure) ?
Old Jul 29, 2003 | 09:49 AM
civictypenos's Avatar
i used the throttle body coolant line,completely bypassed the tb all together,and ran the lines to my turbo,knocked out 2 birds with one stone.
AlAddiN|502
Sep 12, 2010 09:18 PM
Civicman86
Jan 31, 2005 08:47 AM
Soccerking3000
Mar 1, 2004 08:28 AM
GruvyTune
Sep 6, 2002 05:09 AM
