can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars??
Old Jul 28, 2003 | 06:40 PM
mingchi69's Avatar
I to Smooch Pickle
Default can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars??
Im trying to find some polyurethane bushing that I can use for the JDM ITR rear sway bars other than stock. So far, i cannot find someone that makes it, but would i be able to use an energy suspension 23mm front sway bar bushing for the rears?? thanks
Old Jul 28, 2003 | 08:08 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars?? (mingchi69)
anybdoY>?
Old Jul 29, 2003 | 02:44 AM
mingchi69's Avatar
I to Smooch Pickle
bump
Old Jul 29, 2003 | 04:46 AM
Willard's Avatar
the front and rear sway bar bushings are made differently.
just reuse the 22mm rear bushings with the 23mm bar (I did and it worked ok).
apply some marine moly lube and inspect regularly.
Old Jul 31, 2003 | 09:01 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars?? (Willard)
are you sure?? they look pretty damn similar to me. does anybody else have an opinion regarding this?? thanks
Old Aug 1, 2003 | 07:56 AM
BlueR1's Avatar
As Willard stated, the oem 22mm bushings will work.
Old Aug 1, 2003 | 08:07 AM
Flux's Avatar
Default Re: can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars?? (BlueR1)
I reused my 22mm bushings on the 23mm JDM bar as well - works perfectly fine.
Old Aug 1, 2003 | 08:11 AM
Chris N's Avatar
Default Re: can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars?? (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">I reused my 22mm bushings on the 23mm JDM bar as well - works perfectly fine.</TD></TR></TABLE>
We are all sure it works. I've done the same thing.
Old Aug 1, 2003 | 08:27 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingchi69 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure?? they look pretty damn similar to me. does anybody else have an opinion regarding this?? thanks</TD></TR></TABLE>
if you would like I will take pictures of my Delerin sway bar bushings when I get home and post them up.
Old Aug 1, 2003 | 09:27 AM
mingchi69's Avatar
I to Smooch Pickle
it's ok.. thanks for your help though. I went ahead and ordered the bushing from suspension.com
http://www.suspension.com/s.b.bushings.htm
energy suspension 23mm sway bar bushing (part # 9-5127).. hopefully that will work.. and cheaper than stock too..(if you include the d brackets)
Old Aug 1, 2003 | 09:30 AM
JeffNA's Avatar
just the info I was looking for
Old Aug 1, 2003 | 10:03 AM
mingchi69's Avatar
I to Smooch Pickle
Default Re: can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars?? (JeffNA)
so..... do you know if that particular ES bushing will work?? should work right?? o well, ordered it already.. bout to find out.
Old Sep 15, 2003 | 02:05 PM
Vitt1's Avatar
I just called about those and they couldn't tell me if they work or not, I think those are for the Accord. So I tried a search here and came accross this thread. The D brackets measurement look pretty close. Any luck fitting them?
Old Sep 19, 2003 | 06:47 PM
Vitt1's Avatar
Default Re: can i use ES 23mm front sway bar bushing for JDM ITR rear sway bars?? (Vitt1)
ES Part # 9-5127 (actually a mistake on the web site as 905127) works. I just installed it today with the 23mm sway bar on my GSR.
Old Sep 20, 2003 | 08:44 AM
mingchi69's Avatar
I to Smooch Pickle
yes.. i used that exact bushing part for my car. The polyurethane bushing is very stiff.. almost feels like plastic.. but i guess it works.
d-yup
Jul 6, 2009 10:04 AM
bgcrx
Northern California (Sales)
Nov 22, 2007 05:09 PM
GreenBean
Feb 26, 2004 01:01 PM
