pulley torquing
Old Jul 28, 2003 | 03:38 PM
david90's Avatar
Default pulley torquing
I have 95 accord v6. Can you use the method of stepping on the brake to hold the crank pulley still while torquing it on an automatic car? Also, why does the pedal gets harder to press with every press?
Old Jul 29, 2003 | 03:45 AM
JimBlake's Avatar
Default Re: pulley torquing (david90)
Won't work. No matter how hard you press on the brake, with an automatic transmission the engine can still spin.
Your brake pedal gets harder because each time you press it you're 'using up' some of the vacuum that's stored in the brake booster.
Old Jul 29, 2003 | 10:58 AM
david90's Avatar
is it ok if I use the brake method when torquing ON the bolt? Taking it off, i'm gonna use 600 lbs elctric impact so i'm ok with that.
Robert17crv
Suspension & Brakes
11
Nov 2, 2017 01:36 PM
BornToHula
Mar 3, 2012 08:50 PM
1991hondahatchsi
May 26, 2006 05:09 PM
servion
Feb 26, 2004 05:07 PM
citanest
18
Jul 6, 2001 01:41 PM
