What could be the problem?
Old Jul 28, 2003 | 03:24 PM
Dirtman's Avatar
Default What could be the problem?
I have a 94' ls, in stock form I ran 16.5. About 50k miles later ( 154k now) and a few bolt ons (DC 4-2-1, AEm cold air, UR under drive pulleys and a race cat "Landspeed") i ran an awsome 17.2 . Just a couple of more details to add, I had installed a Fuel pressure regulator boosting pressure from 34 psi to 39 psi. I did'nt get in 4th gear til' about 150-200 feet to the finish line. My first check will be compression, but I dont think thats it , it's a honda. If you have any logical conclusions i appreciate it.
Old Jul 28, 2003 | 03:47 PM
976's Avatar
976
New User
Default Re: What could be the problem? (Dirtman)
Tune-up, drop the fuel pressure, you might have rasied too much. Tire pressure. Compression test give good insight.
Old Jul 28, 2003 | 07:17 PM
chevyalltheway's Avatar
sounds like you raised the fuel pressure too much. go to the track and test it at different psi.
Old Jul 28, 2003 | 07:27 PM
poison's Avatar
Check plugs, cap/rotor, and lower fuel pressure.
Old Jul 28, 2003 | 08:35 PM
MightyMouseTech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirtman &raquo;</TD></TR><TR><TD CLASS="quote">I have a 94' ls, in stock form I ran 16.5. About 50k miles later ( 154k now) and a few bolt ons (DC 4-2-1, AEm cold air, UR under drive pulleys and a race cat "Landspeed") i ran an awsome 17.2 .
OK, this may sound obvious, but were both slips at the same..
-temperature
-humidity
-track
-tire pressure (or tires for that matter)
-car weight (did you add some monster heavy sub box?)
-did you eat nothing but burritos for a full year and put on 200lbs?
-was the engine in the same state of tune (plugs, valve adjustment...)
Hawaii Da9
Jan 24, 2006 12:29 PM
fitboy
Oct 16, 2004 02:12 AM
