what turbo to use on the h22
Old Jul 28, 2003 | 02:45 PM
d98clturbo's Avatar
Default what turbo to use on the h22
i am asking this question here becuase i think you guys know your stuff (when talking about h22's
i am upgrading from a T3/TO4B (small) turbo
i have 2 turbos in mind which size do you think i should use: this will be going on my daily driven acura...what do you guess think is best?
I will be boosting 15psi
T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
or
T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
thanks for your help
Old Jul 28, 2003 | 02:56 PM
rjr162's Avatar
Default Re: what turbo to use on the h22 (d98clturbo)
The T3/TO4E with the .63 A/R housing should work fine. My brother is using that setup with 11 psi currently. (errr... crap.... I'm like 99% sure it's a .63 A/R.. i forget now)
Old Jul 29, 2003 | 07:22 AM
d98clturbo's Avatar
Default Re: what turbo to use on the h22 (rjr162)
ttt
Old Jul 29, 2003 | 03:05 PM
LJR-LUDE01's Avatar
those two turbo are pretty similiar, i think the major differents will be where would you make more power. a .82 a/r would give you more top end and a .63 a/r would give you more power on the bottom end. Hope that help if I'm wrong probably someone else will let me know "flame suit on"
Old Jul 30, 2003 | 12:20 PM
Old_Nocturnal's Avatar
The .82 is going to flow more air, thus leaving room for alot of growth on your top end, but naturally, it will take longer to build pressure flowing that much air.
What you probobally need to look at are the your personal goals for the car. If you plan on building the hell out of the bottom end and running obscene amounts of boost, get the .82. You might need a shot of juice to spool it up, but hey...
The biggest turbo I have seen on a Prelude kit is a t3-t04e at about .63, so that might be something to look at. Revhard claims their .63 t04e is efficent to 450 hp, so that will probobally be more than enough. Assuming you won't be running over 450 hp. If you do, come get me! I wonna ride!
Hulkmanj99
Oct 14, 2004 12:49 PM
underpressure02
Feb 10, 2004 07:26 AM
HYBRID_H@TCH
Aug 26, 2003 12:30 AM
d98clturbo
Jul 29, 2003 06:22 PM
specie
Jan 15, 2003 05:52 PM
