Getting Rid OF This
Hey, just wondering what i can use to get rid of the residue left over after taking honda model sitcker off
http://www.we-todd-did-racing....DE%3D
Goof-off is probably your best bet. I had to remove sticker/badge leftovers from my old accord and my girl's accord, and it worked very well without any visible damage to the paint. You can pick up a can of that stuff at Sears or OSH, I think it works better than WD40 on removing sticky stains like that.
i have goo gone, but i dont have the plastic scraper that comes with it so its bascially useless, unless i can find something else to scrap with could/should i use a razor blade?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nader_D »</TD></TR><TR><TD CLASS="quote">ive heard wd-40 can take it off, but is that safe to spray onto the body of my car?
That's what I use. Just apply liberally and wipe in a circular motion.
When you're done with the goof-off you may want to buff up the area with some polish to try and get the paint shades to match. The paint that has been hit by the sun over the years may be a bit discolored and different from the area under the stickers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nader_D »</TD></TR><TR><TD CLASS="quote">i have goo gone, but i dont have the plastic scraper that comes with it so its bascially useless, unless i can find something else to scrap with could/should i use a razor blade?
Um, definitely don't use the razor blade. You would hate yourself if you did.
nothing....
what it is is probably faded paint, there might be a little sticky stuff on there that you could get off, but there will always be a mark.
i have it from my pin stripes on the side of my car.
i work at a car lot and the painters and detailers said there is nothing you can do about it. you can buff it a little but you can still see it
i have it from my pin stripes on the side of my car.i work at a car lot and the painters and detailers said there is nothing you can do about it. you can buff it a little but you can still see it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">goof off.</TD></TR></TABLE>
YIKES!! I would highly advise not using goof off or goo gone, I have used this stuff on my interior paint and it ate right through to the metal. You won't notice on the outside, because you have clear. Use wd-40, and if that doesnt work, get some very light cutting compound, like 3m brand and buff that area, or you could try a clay bar.
thanks, used goo gone and it came off
my problem before was that i didnt let it sit long enough + wasnt using a strong enough cloth
thanks for the help
thanks for the help
