will dx axles work with the b18c1 swap
Old Jul 28, 2003 | 01:23 PM
tonesdef's Avatar
Default will dx axles work with the b18c1 swap
just need to know becuase hmotors online sells just the motor ecu and tranny than they sell the complete change over do i need to whole change over or can i use the my axles and shift linkage
Old Jul 28, 2003 | 01:28 PM
Need4Boost's Avatar
Default Re: will dx axles work with the b18c1 swap (tonesdef)
Get the whole complete swap motor, tranny, ecu, axles, wiring harness...everything. Your dx stuff won't work. You could always just order that stuff motor, ecu and tranny and look for that other stuff local. (What ever is the cheapest)
Old Jul 28, 2003 | 05:05 PM
ransack's Avatar
Default Re: will dx axles work with the b18c1 swap (Need4Boost)
cant use axles
b18 uses a intermediate shaft, the DX didnt
Old Jul 28, 2003 | 05:56 PM
poison's Avatar
Nope, DX axles will not work. you will need 94+ B series axles.
Old Jul 28, 2003 | 08:07 PM
b20_ed's Avatar
Default Re: will dx axles work with the b18c1 swap (poison)
your shift linkages will be short, I think you use the ones for an integra or from an Si
Old Jul 28, 2003 | 08:15 PM
poison's Avatar
Default Re: will dx axles work with the b18c1 swap (b20_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK &raquo;</TD></TR><TR><TD CLASS="quote">your shift linkages will be short, I think you use the ones for an integra or from an Si</TD></TR></TABLE>
yep, 94+ B series shift linkage will work as well.
Stoich
Sep 28, 2005 02:49 PM
vegaskurt
Jan 20, 2005 08:13 AM
Spoonedcivic
May 19, 2004 06:19 PM
EFing8
Jul 15, 2003 02:16 PM
projectcrx
Mar 26, 2003 09:57 PM
