205/50/15 or 195/50/15 for drag racing?
Old Jul 28, 2003 | 11:39 AM
B18Redline's Avatar
Default 205/50/15 or 195/50/15 for drag racing?
Which of the following sizes for tires are better for drag racing...I am going to be using this for a street driven car as well.
I was looking at 195/50/15 OR 205/50/15
Also if I were to get 16" wheels and use this size: 205/45/16, would it make a big difference at the track as compared to the tire sizes above?
Thanks!
Old Jul 28, 2003 | 01:01 PM
paulzy's Avatar
Default Re: 205/50/15 or 195/50/15 for drag racing? (Redline07)
the 205/50/15 will have more meat to grab and a wider patch to hook
Old Jul 28, 2003 | 01:04 PM
TwoRedEGgs's Avatar
For the best traction you will need the biggest contact spot, so i would go with the 205's. Also what tires are you going to use cause that will make a big difference too.
The falken azenis have great grip and so do the yokohama es100's along with some kuhmo tires so make sure you get a good tire !
Old Jul 28, 2003 | 02:12 PM
quikB18B's Avatar
Default Re: 205/50/15 or 195/50/15 for drag racing? (TwoRedEGgs)
205/50/15 The more contact patch the better.
Old Jul 29, 2003 | 05:58 AM
B18Redline's Avatar
Default Re: 205/50/15 or 195/50/15 for drag racing? (quikB18B)
thanks everyone ...I was looking into the Falken Azenis, Toyo T1-S, and Yokohama AVS100...
Old Jul 29, 2003 | 08:57 AM
Drag R's Avatar
the beefier the better...if u have the power behind it of course......205/50/15, 225 if you got serious power.
Old Jul 29, 2003 | 11:47 AM
89LX306's Avatar
New User
Contrary to what everyone else is saying...
The skinniest tire you can keep on the drive wheels and keep traction the better. In the first 60 feet the tires push the car. In the next 1260 feet rolling resistance becomes the issue. If you can keep the same traction with a 195 as you can with a 205, theoretically you will go faster with the 195 due to less rolling resistance.
Afterall you are only talking about 10 millimeters. That's not even half an inch of extra rubber.
EDIT: Ignore the signature. That is for the Kills newbies.
PreyStayShun
Mar 7, 2011 01:20 PM
da'ee
Mar 25, 2008 10:52 AM
EMphaticONE
Nov 1, 2004 04:28 PM
Chaze*R
Jul 23, 2002 10:33 PM
usuck
11
Apr 30, 2002 10:01 PM
