does anybody know how to make a 70mm throttle body gasket for b-series motor?
Old Jul 28, 2003 | 09:20 AM
91integraLSVTEC's Avatar
Default does anybody know how to make a 70mm throttle body gasket for b-series motor?
i got an str 70mm tb and it didnt come with a gasket.. i'm sure sum of you guys made your own?? if so what material did you use and how did you bore it out?? thanks in advance
Old Jul 28, 2003 | 10:04 AM
Grocery Getter's Avatar
Default Re: does anybody know how to make a 70mm throttle body gasket for b-series motor? (91integraLSVTEC)
i purchased a type r tb gasket , and put it on the tb and shaved it out a bit with a razor or you can use a dremel.
its very simple.
-tim
Old Jul 28, 2003 | 10:20 AM
Don Napier's Avatar
Import Alliance
Default Re: does anybody know how to make a 70mm throttle body gasket for b-series motor? (Grocery Getter)
I make them out of the same plastic as the insulating intake manifold gaskets I make. Letme know if you are interested.
Fo-Do Fanatic
Feb 14, 2011 10:27 AM
eg6sir88
Jan 21, 2007 03:52 PM
Stock@$$GSR
11
Aug 1, 2006 07:12 PM
Peter Langly
Jun 18, 2004 03:19 PM
Jerry
Feb 9, 2003 07:46 PM
