My GSR Quarter-Mile Times...first time at the track
Old Jul 28, 2003 | 05:59 AM
B18Redline's Avatar
Default My GSR Quarter-Mile Times...first time at the track
First time I got a 16.5 because I hit the revlimiter in first gear...Second time I got a 15.3, and last I got the following time...
R/T *** 1.068
60' *** 2.347
1/8 *** 9.9 @ 72 mph
1/4 *** 15.2 @ 92 mph
This is a GSR with full interior, exhaust, obd1 gsr ecu, and AEM CAI. I was running on steelies. The front tires are 195/60/14. The back tires are 185/65/14. How do you guys think I did? I think I can improve, I didn't get a good launch.
Old Jul 28, 2003 | 06:14 AM
JDMBrian's Avatar
Default Re: My GSR Quarter-Mile Times...first time at the track (Redline07)
I think you should drop the air pressure in the front tires about 10-18 psi.
and the rear raise the psi about 40, to cut the rolling distance. also dump the clutch at the last yellow on the christmas tree
Old Jul 28, 2003 | 07:25 AM
Dirtman's Avatar
That is actually a very good run for stock internals, keep it going.
Old Jul 28, 2003 | 09:08 AM
BlackSage's Avatar
I am impressed. I did not know gsr's got so low with just intakes. But whats up with the obd I ECU?
Old Jul 28, 2003 | 09:21 AM
FormulaGSR's Avatar
Default Re: My GSR Quarter-Mile Times...first time at the track (BlackSage)
Its not bad. Try lowering the RF tire a couple pounds lower than the LF. IT will help stop the one tire fire you may be getting. Also advance your timing, its free and it'll help.
I went 9.8 in mine at the 1/8th all stock except for the timing advanced, a $20short ram and a set of Azenis.
Old Jul 28, 2003 | 11:33 AM
AllmotorJunkie's Avatar
Good times for your first time at track
Old Jul 28, 2003 | 11:42 AM
illi Adik's Avatar
Get some better tires and you will see those times improve even more.
Old Jul 28, 2003 | 11:45 AM
quikB18B's Avatar
Default Re: My GSR Quarter-Mile Times...first time at the track (Jackson4Door)
Good times, considering your mods Pick up some azenis and go pratice some more and you can break into the 14's
Old Jul 29, 2003 | 05:59 AM
B18Redline's Avatar
thanks for the compliments
guy_from_nerk
Sep 5, 2011 03:04 PM
slooogsr
May 22, 2007 08:10 AM
xprohx
May 20, 2004 08:22 AM
FusionEg6
Aug 19, 2003 06:57 PM
B18Redline
Jul 29, 2003 11:02 AM
