bangin gears
Old Jul 28, 2003 | 02:21 AM
blakacintegera's Avatar
Default bangin gears
which holds up better to bangin gears at high rpm.... gsr tranni or type r tranni?
Old Jul 28, 2003 | 08:56 AM
J337_UNIT's Avatar
Default Re: bangin gears (blakacintegera)
my guess would be an ITR tranny only because it has an LSD (limited slip differential) but both trannys are built the same with the same metal just with different gear ratios..and actually wat matters most is your clutch
Old Jul 28, 2003 | 09:04 AM
NeoGSR's Avatar
Default Re: bangin gears (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">my guess would be an ITR tranny only because it has an LSD (limited slip differential) but both trannys are built the same with the same metal just with different gear ratios..and actually wat matters most is your clutch</TD></TR></TABLE>
wrong!!!
the ITR tranny is different, it's built heavier with dual-cone synchros and other good stuff like that......
Old Jul 28, 2003 | 09:29 AM
J337_UNIT's Avatar
Default Re: bangin gears (NeoGSR)
my bad......
Old Jul 28, 2003 | 09:33 AM
romeo619romeo's Avatar
all i kno b16 tranny seems to break alot easier the gsr and itr.. usually the differential.. friend broke 2 already..and hasnt broe the gsr since he switched to that
Old Jul 28, 2003 | 09:37 AM
Tweakmeister's Avatar
more parts = more chance of failure (ITR)
I'd still rather have a JDM ITR tranny for the final drive and lsd, along with short gearing.
Old Jul 28, 2003 | 10:57 AM
TEXN3's Avatar
Default Re: bangin gears (Tweakmeister)
maybe if you don't bang the gears, you'll be better off. in a honda, shifting with alot of force will slow you down because they are designed to be shifted very smoothly and with ease. ever drive an s2k or rsx/tsx? you'll learn that shifting too hard will slow you down. i learned to drive on a 1968 oldsmobile 442 with a big ole hurst shifter and you had to use force. thats why i learned the hard way about hondas.
Old Jul 28, 2003 | 11:01 AM
cw98typer's Avatar
Default Re: bangin gears (texnteg)
ITR has lsd and better gear ratios.
Old Jul 28, 2003 | 12:21 PM
alfaaay's Avatar
Default Re: bangin gears (cw98typer)
call me stupid, but what does "bangin' gears" mean?
Old Jul 28, 2003 | 12:25 PM
B16OnTop's Avatar
Default Re: bangin gears (alfaaay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">call me stupid, but what does "bangin' gears" mean?</TD></TR></TABLE>
slamin it into every gear as hard as you can, kinda like when i try to shift fast and clean....still cant do it
Touch
Jun 9, 2005 10:04 PM
stumpyf4
Nov 9, 2004 08:09 PM
KHowe
Feb 9, 2004 10:35 PM
geminis2k
Sep 24, 2003 09:39 AM
skafia
Nov 21, 2001 01:25 PM
