Fuel Pressure B16a b&M Fpr
Old Jul 28, 2003 | 12:24 AM
Lysawy's Avatar
Default Fuel Pressure B16a b&M Fpr
So here is the fuel pressure problem, to what psi should i set it , with my old cx fuel pump i had 34psi idle and 40psi at WOT with the vac line on The motor is b16a I/h/e timing at 17btdc ..
with my holley fuel pump i had 39psi idle and 44psi at wot and my cat fell apart so i gutted the cat and had lean condition (white spark plugs) .. Well now i got a new cat and just put my B&M fpr on and i'm on 46psi idle and 50psi at wot No smoke or anything what a correct setting would be with my setup.... help asap.... all those readings are with the vac line ON>>>
isn't that little too much for a stock motor.... test drove it and now it responds kinda better hard to tell and my idle now seems steady not jumping around like it used too....
Old Jul 28, 2003 | 07:45 AM
WAFFLES's Avatar
Default Re: Fuel Pressure B16a b&M Fpr (Lysawy)
I dont know how much you should run with the CX fuel pump, but I know stock psi at idle is 38psi with stock Fuel Pump. Now I'm thinking d series fuel pumps are the same as the B16 fuel pump. Not sure though. I know the B16 pump flows less than the gsr/itr pump, but not exactly how much.
I have a turbo eclipse fuel pump, which flows a little more then the stock B series pumps. I currently have my fuel psi set at 32psi at idle. No smoke(fuel) at WOT.
boostd92
Sep 1, 2006 05:45 PM
b16hatche
Nov 11, 2005 06:28 PM
UNKNOWN_MEMBER
Aug 16, 2005 01:29 AM
Tchleung
Oct 18, 2004 01:48 PM
Stinkalope
Mar 26, 2002 10:29 AM
