help wont start?
Old Jul 27, 2003 | 10:29 PM
hondaspeder's Avatar
Default help wont start?
ok so i put a 2000 civic si motor in my hatch untill my gsr motor is finished at the machine shop....
will not crank....
no check engine light....
full tank of gas...
getting spark too the wires...
i did not change the plugs has some ngk's in it....
when you turn it over it just pumps like there are no cylinders firing off at all....
no poping or sputtering just sounds like i unpluged the ecu and iam trying to crank it....
what do you guys think?
any suggestions would be greatly appreciated
Old Jul 27, 2003 | 10:32 PM
mmuller's Avatar
Mad Scientist
Default Re: help wont start? (hondaspeder)
if you are getting spark then its gas, are you getting fuel pressure?
Old Jul 27, 2003 | 10:39 PM
Stripped Honda's Avatar
99-0104
Default Re: help wont start? (mmuller)
sounds like you forgot a ground wire
Old Jul 28, 2003 | 07:28 AM
both grounds are connected
40psi of fuel
new gas
Old Jul 28, 2003 | 11:53 AM
mmuller's Avatar
Mad Scientist
Default Re: (hondaspeder)
have you tried swapping ecu's?
Old Jul 29, 2003 | 01:40 AM
ok so i figured out this morning that it was my head that was bad so i swapped on one i just got back from the machine shop got everything back to good and cranked her right up.... purrs like a baby except for the minor intake mani leak and timming needs to be adjusted everything is fine and dandy....
this is what its doin now....
when you hit the gas it boggs down like its losing power.. i think this is the intake mani leakage if anyone has had this problem before let me know thanks
russian239
Sep 19, 2014 07:19 AM
slateEKsi
Jan 31, 2011 04:08 PM
akacoke
Jan 19, 2011 09:47 PM
slamLOWnBANGIN
Aug 27, 2010 08:29 AM
Ri5e
Apr 3, 2002 12:08 PM
