new 95 gsr feels slugish, any advice?
Old Jul 27, 2003 | 10:19 PM
oMek's Avatar
Default new 95 gsr feels slugish, any advice?
i just got a 95 gsr its got 146k miles on it. i took it to 3 mechanics they all said its fine and runs good, but to me it feels kinda slugish before vtec hits. i raced a sohc accord and got smoked 1st and 2dn gears, 3rd i took him quick. we raced 2 times like this. any ideas what it could be? im thinking maby i launch to low? its my first car with vtec my last car was sohc. i think maby im use to low rpms of non vtec sohc. is it really that bad to rev the **** out of my car?
Old Jul 27, 2003 | 11:00 PM
romeo619romeo's Avatar
Default Re: new 95 gsr feels slugish, any advice? (omekone)
the motor is made to rev.. but.. maybe its the weight your feeling...or you need to do a tune up.. cap rotor wires plugs...and better gas "premium only"
Old Jul 27, 2003 | 11:09 PM
oMek's Avatar
Default Re: new 95 gsr feels slugish, any advice? (romeo619romeo)
i changed oil and plugs i got plat 4+ bosh, what else would you sujest i do i know its got alot of miles and prob hasent hade service in a while
Old Jul 27, 2003 | 11:10 PM
oMek's Avatar
i also bin running only the prem gas since i got her, no idea if that guy did or not. the oil was block as ****
Old Jul 27, 2003 | 11:17 PM
p1ccoloz's Avatar
you just got it right? yea i'm thinking your not used to the little low end torque...launch high and rev the baby, it'll love you for it!
Old Jul 27, 2003 | 11:23 PM
oMek's Avatar
Default Re: new 95 gsr feels slugish, any advice? (p1ccoloz)
which bolton mods are good for low end?
iH8RICERZ's Avatar
gsr's make good power in the midrange........warm weather can also make the car feel sluggish. It is required that you use only premium in the GSR...so your on the right track....launch higher, and you'll be in the power ban
Old Jul 28, 2003 | 04:53 AM
MikeTV
Guest
Posts: n/a
Default Re: new 95 gsr feels slugish, any advice? (iH8RICERZ)
1rst of all take out the bosch +4s, I've heard bad things about them. According to some people, they can really do a number on your cars. replace them with NGK coppers from pepboys. Second, make sure you changed the fuel filter, air filter, wires, cap and rotor ( for the cap and rotor, only use oem honda parts). After that is done, make sure your oil is topped off, and begin practicing launches at around 4k, closer to 5k if you have very grippy tires. You should notice a dfference.
Old Jul 28, 2003 | 05:48 AM
StyleTEG's Avatar
Default Re: new 95 gsr feels slugish, any advice? (Eclipse spanker)
Your driving a small displacement NA four cylinder, its going to feel sluggish until you get higher in the RPM range.
Old Jul 28, 2003 | 07:23 AM
Tweakmeister's Avatar
Default Re: new 95 gsr feels slugish, any advice? (StyleTEG)
Following maintenance (including valve adjustment)
Throw a decent header (bolt-ons...I/H/E) and I think you'll find it wakes up a good bit.
Old Jul 28, 2003 | 09:45 AM
IntEGNYC's Avatar
Default Re: new 95 gsr feels slugish, any advice? (Tweakmeister)
4-2-1 headers will improve the low end.
4-1 for high end.
Old Jul 28, 2003 | 09:53 AM
Default Re: new 95 gsr feels slugish, any advice? (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">4-2-1 headers will improve the low end.
4-1 for high end.</TD></TR></TABLE>
this is not applicable to all headers.
Old Jul 28, 2003 | 10:01 AM
J-g-D-s-M-r's Avatar
gsr don't have much torque so launch higher and use prim. gas only. a tune up might help... like swap out thos sparks n use ngk's. you know the rest.
Old Jul 28, 2003 | 10:13 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">Following maintenance (including valve adjustment)
Throw a decent header (bolt-ons...I/H/E) and I think you'll find it wakes up a good bit.</TD></TR></TABLE>
Yeah, get a valve adjsutment. I need one pretty bad too! Also change the cap and rotor on your distributor. Change out your fuel filter too.
IMO, then drive her HARD and see if that helps.
However, the 3rd gear in the GSR is feirce as hell. So dont be surprised if you didn't pickup a significant lead on the Accord you were racing. On most cars I race, I dont pull on them till 3rd. Then it's over.
Old Jul 28, 2003 | 11:38 AM
SilverDc2's Avatar
Default Re: new 95 gsr feels slugish, any advice? (P1mpSlap)
a gsr is a fuel economy car man,
Old Jul 28, 2003 | 11:44 AM
Default Re: new 95 gsr feels slugish, any advice? (SilverDc2)
i think your jus tnot use to it yet
Old Jul 28, 2003 | 12:15 PM
alfaaay's Avatar
I thought my GS-R was slow when I test drove it. Then I started beating people...a lot of people. It takes some time to get acquainted with the car. With that many miles, a full tune up wouldn't hurt either.
Old Jul 28, 2003 | 12:29 PM
oMek's Avatar
Default Re: new 95 gsr feels slugish, any advice? (alfaaay)
yoday im gona change my wires, cap, and roter. see if that helps. are the plat4+ bosh really that bad, they cost me 6$ each now i gota get more??
Old Jul 28, 2003 | 12:37 PM
Joel_MN's Avatar
yeah, i run only 92 octane in my GS-R. That and the 55 shot make her feel real snappy at 4k rpms.
Old Jul 28, 2003 | 01:34 PM
Try2Live4God's Avatar
Well 4-1 headers are recommended for the Integra since you have VTEC for mid-range power. 4-2-1 is said to be for the low end...but you don't want low end, you want high end power!
Old Jul 28, 2003 | 03:59 PM
mickey513's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omekone &raquo;</TD></TR><TR><TD CLASS="quote">are the plat4+ bosh really that bad, they cost me 6$ each now i gota get more??</TD></TR></TABLE>
Garbage, throw them in the trash and pick up ngk.
FrankLynch4
Apr 26, 2016 07:45 PM
JDM_JUNKIE_DA
Mar 25, 2012 07:19 PM
P1mpSlap
Apr 1, 2003 04:41 AM
2camsaam
Oct 1, 2002 04:04 PM
