Bad idle after one run in the quater mile....
Old Jul 27, 2003 | 09:42 PM
caLiH22A's Avatar
Default Bad idle after one run in the quater mile....
ok here's what happened, my brother went to california speedway(1/4 track) yesterday and after running his 2001 Prelude SH it began to stall at idle. from what i can tell it seems like the timing went off becaue it idles real rough, like the motor shakes and you can hear pausing in the exhaust tone. in order for the car to stay idleing you have to keep your foot on the gas. some previous problems that he had also was that when he would make a turn the car would turn off for no reason but he never payed to much attention to that, you guys have any idea what can cause the car to die when making a turn, or what might had happen during his run at the track? thanks.
Old Jul 27, 2003 | 10:17 PM
rjr162's Avatar
Default Re: Bad idle after one run in the quater mile.... (caLiH22A)
possibly a bad fuel pump or a relay? Does it seem to do it more on a more empty tank than a full one? Any other symptoms you can give, or exactly the condistions it seems to do it more would be of much help
Old Jul 27, 2003 | 10:25 PM
imported204's Avatar
Default Re: Bad idle after one run in the quater mile.... (rjr162)
I dont see how a the fuel pump could go bad on a 2001. If the timing did go off, stop driving the car immediately.
Old Jul 28, 2003 | 05:20 AM
rjr162's Avatar
Default Re: Bad idle after one run in the quater mile.... (imported204)
beats me, but i've seen stranger things
Old Jul 28, 2003 | 05:34 AM
Firedrake's Avatar
My guess would be he missed a shift or something, over revved it, and bent some valves......
Brian
Old Jul 28, 2003 | 08:48 AM
prelittlelude's Avatar
do a compressiona nd leak down test to eliminate posible valve or ring landing damage. then if all is good there work your way thru the spark and fuel . good luck you need to start some where. with the symptoms you talk about it could be anything almost, even a bad plug, but start some where start elminating things, and people on here can help you more as it gets more specific
Old Jul 28, 2003 | 03:51 PM
caLiH22A's Avatar
Default Re: Bad idle after one run in the quater mile.... (Firedrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake &raquo;</TD></TR><TR><TD CLASS="quote">My guess would be he missed a shift or something, over revved it, and bent some valves......
Brian</TD></TR></TABLE>
BINGO! the car was taken to the dealer today and we found out that cylenders 1 and 2 had bad compression, they said that some valves were bent also due to an overrev. i aksed my bro but he denies mis-shifting, now the car is out of service, the worst thing about it is that it only has 13,5xx miles
anyone have any H22 valves for sale? someone correct me if im wrong but 93+ H22's have the same valves right?
Old Jul 28, 2003 | 04:22 PM
AndyD's Avatar
Quick question. If the valves are bent would that mean that the pistons are damaged??
The Honda dealership must see a lot of cases like this I bet.
Old Jul 28, 2003 | 06:03 PM
LudeyKrus's Avatar
Default Re: Bad idle after one run in the quater mile.... (AndyD)
Nah, bent valves don't necessarily mean damaged pistons.
Just go to Autozone/Napa and get some new ones; they're only like $15 a piece.
phelpsj2
Apr 4, 2011 07:14 PM
accord_raffi
May 6, 2009 10:06 AM
gooberwolf
Aug 6, 2003 01:59 PM
B00ST2nR
Sep 5, 2002 03:37 PM
