hondata hates my car WTF ????
ok so my setup was complete
my car was running fine with no CELs
so i took my car to have my turbo setup installed and tuned
it turns out
"I have tried three Hondata prepped ECU's in your car, none of them want to work correctly. They all throw a different code, and the car wont run at all for me to even street tune it. I have spent at least 10 hours trying various tricks and diagnosing the sensors to figure out what is going on with no results. All three of those Hondata ecu's are from working cars, with no codes. They all operate correctly, and they have all been tuned by me making good power. "
what do i do now
it turns out
what do i do now
Does this mean your tuner just threw in a pretuned hondata into your car and expected it to work?
i always thought you should run a base map then tune...
sorry, just posting to up the count.
need to vouch for timmay in the classifides, but it won't let me.
again, I appologize, and will let you continue on with your posting uniterrupted.
sound like my 2000 dollar hondata setup.. dont ask i still get pissed off i didnt get ems... but it tends to work for civic/tegras
just wierd that with my pr3 ecu i get no codes
with the p28s get codes
colin my car will be at your shop by 10am on tuesday
I just had a problem with hondata today. Last time I installed it, it worked fine and today witha different base map, the light is blinking on the blue box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline201 »</TD></TR><TR><TD CLASS="quote">just wierd that with my pr3 ecu i get no codes
Umm...the PR3 is OBD0 and the P28 is OBD1, This sounds like a problem to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25 PSI CRX »</TD></TR><TR><TD CLASS="quote">I just had a problem with hondata today. Last time I installed it, it worked fine and today witha different base map, the light is blinking on the blue box.</TD></TR></TABLE>
Make sure it is the correct ROM version.
I am interested to see the outcome of this diagnostics with RPM NYC.
RPM bought a bunch of ECUs from me with no issues.
I highly doubt the ECU I sent you is a P06, it is your Hondata issue.
I hope this will get resolved, so I can be on my feet again.
