eg hatch..itr swap...what intake?
Old Jul 27, 2003 | 08:32 PM
B_1_8_hatch's Avatar
Default eg hatch..itr swap...what intake?
with a usdm itr swap in an eg hatch..what cold air intake can you use? do you use the 92-95 civic cai or the itr cai?
anybody have any pics
Old Jul 27, 2003 | 08:38 PM
ridiculous's Avatar
Default Re: eg hatch..itr swap...what intake? (93hb)
i would put my money on the integra cai, since it goes on the itr motor.
Old Jul 27, 2003 | 09:39 PM
are the 92-95 civic and integra cai the same shape piping?
Old Jul 27, 2003 | 09:40 PM
EGRhatch's Avatar
Default Re: eg hatch..itr swap...what intake? (ridiculous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridiculous &raquo;</TD></TR><TR><TD CLASS="quote">i would put my money on the integra cai, since it goes on the itr motor. </TD></TR></TABLE>
im with him ^^^^^
get the comptech coldair, "icebox" i believe its called, looks stock and has pretty good gains.
Old Jul 27, 2003 | 11:17 PM
Mike Ockhurts's Avatar
i think u r gonna need the otr cai, cuz i believe that the intake manifold is bigger on the itr. sumone correct me if im wrong
Old Jul 27, 2003 | 11:21 PM
Mar_DC2's Avatar
use an ITR CAI.
Old Jul 27, 2003 | 11:29 PM
MPower332TI's Avatar
Default Re: eg hatch..itr swap...what intake? (Btown_99Si)
I would go with the V2 for the 99-00 civic si. It should fit perfect and kicks *** in my opinion. They can be had for as cheap as 240 and i like it alot better than the itr cai which i had before.
Old Jul 28, 2003 | 12:51 AM
SlowazzGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">with a usdm itr swap in an eg hatch..what cold air intake can you use? do you use the 92-95 civic cai or the itr cai?
anybody have any pics</TD></TR></TABLE>
The manifold is different on the ITR than on your civic. I would recommend using the ITR CAI from AEM.
Old Jul 28, 2003 | 01:02 AM
acuracing's Avatar
I'm using an AEM ITR CAI. Works fine.
Old Jul 28, 2003 | 04:47 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I'm using a 99-00 Civic Si AEM CAI.
The ITR version will require you moving your coolant overflow bottle (not a huge deal)and you'll also need to tap a screw to hold the bracket in place on your framerail.
I've seen no ill effects from running the slightly smaller diameter 99-00 Si tubing - I baselined better than any other bolt-ons Type Rin my area at 175/122 with only mods being intake, exhaust, and Kenji ECU. That was before the header and tuning.
Did I mention that the 99-00 Si one fits really awesome with no customizing needed?
I'd show you a pic of mine, but the server I host pics on is currently down. Hell here goes nothing:
The dyno of baseline and after tuning with FPR and V-AFC:
Hope that shows up.
Old Jul 28, 2003 | 07:10 AM
SergEK's Avatar
Default Re: eg hatch..itr swap...what intake? (jDmDxTuRd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd &raquo;</TD></TR><TR><TD CLASS="quote">I would go with the V2 for the 99-00 civic si. It should fit perfect and kicks *** in my opinion. They can be had for as cheap as 240 and i like it alot better than the itr cai which i had before. </TD></TR></TABLE>
The ITR V2 would probably be a better deal....its probably going to have slightly larger piping which could make a few extra hp up top once you have a few more bolt-ons.
Old Jul 28, 2003 | 07:25 AM
WAFFLES's Avatar
Default Re: eg hatch..itr swap...what intake? (SergEK)
They don't make a V2 for the ITR, because they have not been able to make any gains.
Old Jul 28, 2003 | 11:10 AM
Default Re: eg hatch..itr swap...what intake? (B18C5-EH2)
so any 99-00 civic si cai should fit right?
Old Jul 28, 2003 | 11:13 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">so any 99-00 civic si cai should fit right?</TD></TR></TABLE>
Yes
Old Jul 28, 2003 | 11:17 AM
TCLchicago1's Avatar
yep....
Old Jul 28, 2003 | 08:12 PM
EGRhatch's Avatar
Default Re: (TCLchicago1)
B18c5-eh
That is one clean *** engine bay
Old Jul 28, 2003 | 08:44 PM
96hatch96's Avatar
try the integra gsr intake 94-97.. juss go to a performance shop and tell them you want to try it on.. if it doesn't work... juss tell them your looking to buy one from them so they will waste there time to make sure you have the right one...
Old Jul 28, 2003 | 10:10 PM
mooseknuckle's Avatar
Default Re: (EGRhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">B18c5-eh
That is one clean *** engine bay </TD></TR></TABLE>
the cleanest
Old Jul 28, 2003 | 11:11 PM
built562's Avatar
Default Re: eg hatch..itr swap...what intake? (96hatch96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatch96 &raquo;</TD></TR><TR><TD CLASS="quote">try the integra gsr intake 94-97.. juss go to a performance shop and tell them you want to try it on.. if it doesn't work... juss tell them your looking to buy one from them so they will waste there time to make sure you have the right one... </TD></TR></TABLE>
the gsr will not even come close to fitting, look how the gsr manifold and throttle body are position compared to a type-r or b16.
so like everyone already else said, ITR or 99+ si (not ep3)
Old Jul 28, 2003 | 11:15 PM
CivicNA's Avatar
id go with the itr cold air but u will see there are a few places that it hits mainly down by the old intake box platform at least mine does. im gunna cut away about an inch on it and it will be great. hey b18c5 can you come clean my motor bay for me? mine NEEDS it but man its a lot of work to get 9 years of grime off...
Old Jul 28, 2003 | 11:55 PM
aira
Guest
Posts: n/a
Default Re: eg hatch..itr swap...what intake? (CivicNA)
since we're on the intake question, what cai can i use on a 96 hatch if i don't have the hole for it?
Old Jul 29, 2003 | 02:09 AM
spoonej8's Avatar
Default Re: eg hatch..itr swap...what intake? (jdm aira)
dont go cai...lose velocity. go short ram with an air duct
Old Jul 29, 2003 | 05:51 AM
RedheadRacing's Avatar
I am using a Comptech Ice Box set up on my car with the same swap. It is the ITR one because it has larger piping. I love the set up. If you would like some pics let me know and I can get you some. I also have a good price on them if you are interested in buying one.
Shawn
Old Jul 29, 2003 | 05:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: eg hatch..itr swap...what intake? (spoonej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonej8 &raquo;</TD></TR><TR><TD CLASS="quote">dont go cai...lose velocity. go short ram with an air duct</TD></TR></TABLE>
PROVE it.
Oh and what good does it do to suck in underhood temperature air anyways?
Old Jul 29, 2003 | 06:21 AM
E-Rok's Avatar
EPIC TUNING
hahhahahahaa
