b18b with t3t04 turbo in a crx
I have made up my mind that i want to put a b18b in my 91 crx hf. I know ill be able to run mid to low 14's but i want it to go faster. Would a t3t04 turbo runnin 11psi be overkill in it since the car is to light? My friend has a 95 civic and he is runnin a slightly smaller turbo with 7psi, would that be better then the t3t04?
Well...a 91 crx hf w/ b18a will not run mid to low 14's stock, you'll need many mods for that et. But the t3t04 is a great motor for b-series engines, but if i were you i'd get a little smaller trim because the b18a doesn't have high revving capeabilities and you will have more lag then boost. so if you get a t3t04b like for a sohc vtec setup you will make very good power. on 11lbs you should be in mid/low 12's depending on traction and 60ft and driving skills. good luck though! i'm doing t3t04e in my b16 crx si.
95si
Oct 7, 2002 06:46 PM
