How many bulbs behind the CRX cluster (88-89)?
Old Jul 27, 2003 | 04:23 PM
B2FiNiTY's Avatar
Default How many bulbs behind the CRX cluster (88-89)?
I want to change the bulbs to alter the color. I changed out the 3 big 194 bulbs but the middle is still original color. What other bulbs are there and what size? Do I need to change all the bulbs with brown backs?
Thanks.
Old Jul 27, 2003 | 10:20 PM
4crx4me's Avatar
Default Re: How many bulbs behind the CRX cluster (88-89)? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I want to change the bulbs to alter the color. I changed out the 3 big 194 bulbs but the middle is still original color. What other bulbs are there and what size? Do I need to change all the bulbs with brown backs?
Thanks.</TD></TR></TABLE>
The cluster light doesn't get its color from the bulbs. ALL the bulbs are white, I believe. The color comes from a transparent orange piece of plastic at the top of the cluter that the light is directed through.
Old Jul 28, 2003 | 05:44 AM
CRXRageD's Avatar
Are you trying to change needle color? or backlight color?
Old Jul 28, 2003 | 10:11 AM
B2FiNiTY's Avatar
Default Re: How many bulbs behind the CRX cluster (CRXRageD)
I am trying to change the backlight color not the needles.
Old Jul 28, 2003 | 10:12 AM
B2FiNiTY's Avatar
Default Re: How many bulbs behind the CRX cluster (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
The cluster light doesn't get its color from the bulbs. ALL the bulbs are white, I believe. The color comes from a transparent orange piece of plastic at the top of the cluter that the light is directed through.</TD></TR></TABLE>
The 194 bulbs are clear bulbs covered with blue condoms. I don't know about the other small ones. You can definately change the color because half of the cluster is red but the middle is still original color.
Old Jul 28, 2003 | 10:24 AM
4crx4me's Avatar
Default Re: How many bulbs behind the CRX cluster (B2FiNiTY)
The 194 bulbs are clear bulbs covered with blue condoms. I don't know about the other small ones. You can definately change the color because half of the cluster is red but the middle is still original color. </TD></TR></TABLE>
What? What's still in what color? the color it appears to me is projected on the needles from above from that orange piece of translucent plastic that sits on the underside edge of the clusters top.
On my teg that piece of plastic across the top edge is blue, same color as the condoms and the teg gauges appear white at night with a slight blueish tint. Same for the ashtray lights in both cars.
Well, experiment and tell us what you find out. I'd like my CRX gauges to be a darker orange like they were on the 1G CRX's.
Old Jul 28, 2003 | 01:36 PM
B2FiNiTY's Avatar
The middle of the cluster has not changed after I changed out 3 of the 194 bulbs is what I'm trying to say. I will take a pic of it tonight.
Old Jul 28, 2003 | 02:58 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">The middle of the cluster has not changed after I changed out 3 of the 194 bulbs is what I'm trying to say. I will take a pic of it tonight. </TD></TR></TABLE>
What do you mean? by middle of cluster?
I do believe that the reason the color didn't "change" is because the "color" of the illumination in not dependent on what color the bulbs are. It didn't change because the nighttime illumination comes from a combination of direct and indirect light. Some of which shine thru the orange plastic piece across the top.
Try taking a pen light and shine it thru the holes to see which bulb lights up which part of the cluster. (if that makes any sense.)
Old Jul 28, 2003 | 04:51 PM
B2FiNiTY's Avatar
Middle = gas gauge and temp gauges and the surrounding area.
The tach part is red and so is the speedo part.
Old Jul 29, 2003 | 10:39 PM
B2FiNiTY's Avatar
Here's what it looks like now:
Old Jul 30, 2003 | 11:08 AM
crxgator's Avatar
man, how do you see how fast you are going...i can barely see the needle...
Old Jul 30, 2003 | 02:09 PM
CRXRageD's Avatar
So what you're saying is that you changed the bulbs to orange bulbs? How can I make my current cluster brighter?
Old Jul 30, 2003 | 06:23 PM
B2FiNiTY's Avatar
Yes sir I just changed the bulbs. You can buy some xtreme white bulbs from PIAA they work very well.
The needle is easily seen but hard to tell in that pic.
Old Jul 30, 2003 | 06:33 PM
FourthGenHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXRageD &raquo;</TD></TR><TR><TD CLASS="quote">So what you're saying is that you changed the bulbs to orange bulbs? How can I make my current cluster brighter?</TD></TR></TABLE>
There is a stupid orange piece of plastic at the top of it. I took mine out and it made the cluster light up bright white as opposed to dim *** orange.
Old Jul 30, 2003 | 07:07 PM
B2FiNiTY's Avatar
Default Re: How many bulbs behind the CRX cluster (FourthGenHatch)
My cluster lights up white not orange. What year do you have?
Old Aug 5, 2003 | 05:16 AM
CRXRageD's Avatar
Do you have the part number for those piaa bulbs?
Old Sep 30, 2010 | 08:16 PM
JScrxsi's Avatar
It has 5 bulbs.
and you can buy them in superbrightleds.com. led size are #74.
$1.16 each i guess. when i bought. but i dunt know now how much they charge
CivicExMaster
Oct 20, 2008 05:28 PM
EJ8 GSR-T
Feb 24, 2006 02:07 PM
Quetzolcotl
11
Dec 9, 2003 11:42 AM
usdmcrx
Apr 8, 2003 10:57 PM
