what ecu
Old Jul 27, 2003 | 03:53 PM
Ransom's Avatar
Default what ecu
i have the crower 404's, protflow head with port and polish, 3 angle valve job, ti retainers, dual valve springs and skunk 2 manifold. i just want to find out what ecu i should use. And if i chip it what program to use. what do you guys think? oh yea it is a B18a in a 89 civic.
Old Jul 27, 2003 | 05:09 PM
granada_sun's Avatar
best way to reach full potential is to tune with program like hondata + vafc, p28s are perfect for that.
Old Jul 28, 2003 | 01:46 PM
Ransom's Avatar
Default Re: (granada_sun)
i thought that p28's were vtec ecu. can you use a vtec ecu on a non vtec motor?
Old Jul 30, 2003 | 07:43 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (LudeSH)
Well you defenetly don't need a VAFC with Hondata. Also Hondata configures the P28 to run a Non-VTEC motor. I'd go this route.
Old Jul 30, 2003 | 08:27 AM
RedZone's Avatar
Default Re: (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well you defenetly don't need a VAFC with Hondata. Also Hondata configures the P28 to run a Non-VTEC motor. I'd go this route. </TD></TR></TABLE>
If you do go with a P28+Hondata then you will need an OBD0 to OBD1 conversion harness since your car is an 89 civic. Or you can go with a chipped PR4 and an AFC. If you don't want to buy an AFC you can borrow a Vtec controller and use just the fuel side of the unit and tune it on the dyno with the VAFC and then take the settings out of the VAFC and have the person chipping the ecu change the program on your ecu to the settings that are on the VAFC and then you can take the VAFC off and run on just the Chipped PR4.......going with the hondata will give you more tune-ability.....going the PR4 will save you a little bit of money.
Old Jul 30, 2003 | 09:04 AM
gsrvx's Avatar
New User
hondata + vafc?
Old Jul 30, 2003 | 02:01 PM
Since hondata doesn't have adjustable vtec x-over, vafc would be a good idea with vtec motor. Didn't see the b18a part, anywho hondata will do the job and then some.
Old Jul 30, 2003 | 06:10 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">Since hondata doesn't have adjustable vtec x-over</TD></TR></TABLE>
What!?
Old Jul 30, 2003 | 08:41 PM
What!? </TD></TR></TABLE>
my bad, unless its stage 3/4....pre-obd....unless wiring conversion and s100 or s200 are in order, i apologize for the vagueness.
edit*stage 2 is only hondata without vtec xover.
Modified by granada_sun at 2:44 PM 7/31/2003
Old Jul 31, 2003 | 08:48 AM
Mr Hammond's Avatar
a/k/a Jomo
I think I am a little confused with what you are saying. The s100 and s200 both have VTEC control. Hondata recomends using the s100 or s200 unless you have a Pre-OBD ECU like a PW0 or soemthing. Then use old Stage 3-4. Soooo which one were you saying doesn't have VTEC control that you would need a VAFC?
Modified by Mr Milano at 3:37 PM 7/31/2003
Old Jul 31, 2003 | 10:43 AM
stage 2 is the only hondata that doesnt have vtec control, tired last night. But the engine is pre-obd (im pretty sure) b18a, and unless the wiring is converted then only stages 2/3/4 can be used, leaving 3/4 for vtec control. Vafc is cheaper than hondata, not as tuneable, but still a decent piece of hardware.
Old Jul 31, 2003 | 11:35 AM
Mr Hammond's Avatar
a/k/a Jomo
Ahhh. N/M. I see what you are saying about the Stage 2 system. I wasn't reading you right.
jdmredgsr
Mar 30, 2007 05:12 PM
Chicano
Mar 18, 2007 12:07 PM
jdmeg9
Mar 19, 2006 11:37 AM
krystianitr
Apr 5, 2005 09:24 AM
deez nuts
11
Jul 29, 2003 06:10 PM
