Integra radiator hoses
Old Jul 27, 2003 | 03:40 PM
Project X's Avatar
Default Integra radiator hoses
Are the LS radiator hoses (the 2 big ones) same as the ITR's?
Old Jul 27, 2003 | 09:58 PM
Project X's Avatar
Default Re: Integra radiator hoses (Project X)
nobody knows?
Old Jul 28, 2003 | 10:05 AM
Jay J's Avatar
Prince of Zamunda
They should. They don't need replacing till 170k at least
Old Jul 29, 2003 | 06:34 AM
Project X's Avatar
Default Re: Integra radiator hoses (neuspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote">They should. They don't need replacing till 170k at least</TD></TR></TABLE>
I want to get the Samco ones but they have different part numbers for ITR and LS/GSR.
Old Jul 29, 2003 | 06:53 AM
SuzukaBlueAP2's Avatar
The top hose is not the same. The top hose is like the GSR, however the bottom hose is the same as the B16 and B18C5.
Old Jul 30, 2003 | 08:15 AM
migs's Avatar
Default Re: Integra radiator hoses (urbanracer98)
I think they are all the same.
Old Aug 3, 2003 | 08:24 PM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 &raquo;</TD></TR><TR><TD CLASS="quote">The top hose is not the same. The top hose is like the GSR, however the bottom hose is the same as the B16 and B18C5. </TD></TR></TABLE>
I don't get how the ITR and GSR won't be the same since they are base on the same engine. I would understand if the LS isn't the same as GSR/ITR since they are difference engines.
The weird thing is that at Samco, the GSR is same as LS, but ITR is different than those 2.
So, are they all the same or not? Can I get more definite answers?
Old Aug 3, 2003 | 08:28 PM
i understand the confusion also....
http://www.paragonperformance.....html
go there and check the part numbers for the civic si and the integras. The integra RS/LS/GS/GSR all have the same upper rad. hose. and the B16 and B18C5 share the same upper.
Old Aug 3, 2003 | 08:30 PM
IN VTEC's Avatar
The difference is in the upper radiator hose housing placement. PR3 heads have the upper radiator hose housing closer to the intake manifold side, while P74 and P72 heads have the housings closer to the exhaust manifold side.
B18C1 and B18A/B upper radiator hoses are shorter. B18C5 and B16 upper hoses are longer.
Old Aug 3, 2003 | 08:34 PM
db8sirg's Avatar
B16A and Type-R use the same upper hose and LS/GSR(94-up) use the same upper hose. The lower hoses on all B-series are the same.
Old Aug 3, 2003 | 08:36 PM
Default Re: (db8sirg)
if you'd go to that link it would all be sorted out
ludesterS
Oct 26, 2007 04:51 PM
IowayRUlz
May 26, 2007 07:36 PM
bmoua
Mar 14, 2006 12:06 PM
oldskol
Feb 15, 2005 08:10 PM
90crxzc
Dec 20, 2003 08:27 AM
