Help with Air Intake/Headers...?
Old Aug 5, 2001 | 06:39 PM
emay1993's Avatar
New User
Default Help with Air Intake/Headers...?
I am going to install a cold air intake and replace the stock manifold with headers on a 1994 Honda Accord EX. If anyone has any advice/directions I would appreciate the help very much. I am new and learning as much as I can.
Thanks
Eric
Old Aug 5, 2001 | 09:42 PM
5gen-hybrid's Avatar
New User
Default Re: Help with Air Intake/Headers...? (emay1993)
when doing the header spray some lube on them first maybe the night before so it can soak in or spray them first then do the intake.
Old Aug 5, 2001 | 11:11 PM
tensai's Avatar
New User
with the intake...take off the F/R tire and work through the wheel well...the resonator is eay to take off. just some bolts and screws. and then connect the downpipe to the filter throught the wheel well...
Old Aug 7, 2001 | 09:50 PM
dvsOasis's Avatar
Default Re: Help with Air Intake/Headers...? (whiteconfusion)
make sure you have the wheel rubber lining re-attached good...at a honda meet, we tried to remove someone's resonator, but didn't have the right tools...a couple of days later, his wheel tore off the wheel lining...
it also happened to my 5th gen...but it wasn't because i was removing the resonator...something was loose underneath, so we tightened it, but i guess air pressured increased on the freeway, causing it to blow up and send the wheel lining to the wheel
qhiggy
Feb 6, 2013 12:14 PM
shad295
Nov 16, 2012 09:06 AM
dohc_profile
Jul 2, 2007 05:40 PM
pdx_503
10
Jan 23, 2007 07:10 PM
pyrojeff
Jan 17, 2003 07:40 PM
