Wierd sound when engaging clutch
Old Jul 27, 2003 | 02:25 PM
IDMaxGuy's Avatar
Default Wierd sound when engaging clutch
I get a funny squeaking kind of noise when I engage my clutch going into 1st gear. it doesnt do it all the time, but it does do it more often, I checked clutch fluid, added a little, and its fine on that part, could this be a sign my clutch is about to kill itself?? Or could it have somthing to do with axles, brakes, etc. it is definatly coming from the front of the car..
Old Jul 28, 2003 | 05:47 AM
JimBlake's Avatar
Default Re: Wierd sound when engaging clutch (IDMaxGuy)
https://honda-tech.com/zerothread?id=573453
Check out that thread. Maybe you have to grease your throw-out fork.
If you have a cable-operated clutch, there's still a throw-out fork. Have someone work the pedal while you go under the hood & listen, to figure out the location of the noise.
Old Jul 28, 2003 | 06:23 AM
RUBZERK's Avatar
I have that same problem. sqeeky clutch ped.
Old Jul 28, 2003 | 10:40 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDMaxGuy &raquo;</TD></TR><TR><TD CLASS="quote">I get a funny squeaking kind of noise when I engage my clutch going into 1st gear. it doesnt do it all the time, but it does do it more often, I checked clutch fluid, added a little, and its fine on that part, could this be a sign my clutch is about to kill itself?? Or could it have somthing to do with axles, brakes, etc. it is definatly coming from the front of the car..</TD></TR></TABLE>
I have the same problem. It's probably your throw out bearing. I have 111,000 miles. Time for a new clutch kit.
pcorad
Aug 10, 2007 09:57 AM
kihun_cha
Mar 22, 2007 05:16 PM
EK79
Apr 25, 2006 12:19 PM
fanatic
Apr 13, 2005 06:26 PM
SOHC_Brian
Aug 23, 2004 09:58 AM
