JDM CRX Cluster
I have a JDM cluster on my CRX which has been working great until today.
I noticed after I left for a drive the KPH needle was not moving but the odometer was. It stayed like that for about 20miles then the needle started working. What could be the problem? A JDM cluster has an electronic speedo also. Has anyone encounter this problem? Thanks in advance for any and all responses.
If it was a VSS problem, his odometer wouldn't have been moving either because it wouldn't have sent a signal at all to the cluster.
If the odometer was in fact moving, but the needle on the speedo was not moving, then your speedo isn't putting the spin to the wheel that the needle is attached to correctly, or the needle has come loose from the peg it sits on. Time to do some investigative work.
I have a guide which my friend downloaded from a now extinct website. Send me your address and I will make a copy and send to you via regular mail
N1NjA TuRtLE
Sep 12, 2002 07:15 PM
