Driveshaft Shop Axles Problem...
Old Jul 27, 2003 | 11:04 AM
COMplex.'s Avatar
Default Driveshaft Shop Axles Problem...
ok, so i ordered some level 2's for my h22 coupe a couple months ago. finally finished the car, and after driving it normally for a bit (no launching or other activities of the axle breaking sort) i notices a large amount of black black oil/grease all around the rim and part of the engine bay.
well, since DSS refuses to answer their phone, and if they do, frank 'the guy that will handle my problem' is not there, i need some help from fellow HT-ers.
basically, i have no clue what is wrong with it, and i dont know what caused it. however, i know that since i spent close to $700 for axles, this should not be happening. and i should get a fix for the problem.
it was installed properly as well, so i really cant figure it out.
please help thanks
Old Jul 27, 2003 | 12:19 PM
b16turbohatch47's Avatar
Default Re: Driveshaft Shop Axles Problem... (j.fuggi)
hmm i had a really good expiriance with dss it has to be some sort of defect on the pair/axel u got i would send them back and demand new one or my money back, theres cheaper axels but there just as good there call raxels i cant remeber the web site right now but if u end up getting ur money back pm me and ill find it good luck with the project, im sure there just busy they will make it right just ask to talk to talk to who ever it there,
Old Jul 27, 2003 | 02:31 PM
Jonathan_ED3's Avatar
So what you're saying is that the axles don't seal up good on the tranny seals and sling transmission oil all over the place?
I think mine are doing that....at first it seemed like they were sealing, but I'm pretty sure they're not.
When the axles are as far in as they'll go, the tranny seals are still about an inch away from where they SHOULD meet with axles.
I'm also pretty sure they're shuddering when I'm in gear and stomp it.
Old Jul 27, 2003 | 05:17 PM
T4eg's Avatar
Default Re: Driveshaft Shop Axles Problem... (Jonathan_EH)
are they cv boots ripped? if they are i think you can replace them with honda ones. some correct me if you cant
Old Jul 27, 2003 | 05:21 PM
COMplex.'s Avatar
i think the grease is coming from the rim side of the axle. theres nothing noticeable on the tranny side. its not the orange tranny fluid, its just straight up black oilish crap. probably the boots. but i didnt do anything to cause brand new axles to rip boots. i dont want to use stock honda ones i spent $700 for a reason, i want it right.
thing that sucks is DSS doesnt cover boots. even though, theres no reason i can think of for the boot to be messed up
Old Jul 28, 2003 | 07:54 AM
what's the 'oem' axle combo for Hasport mounts? I think I'm going to try those out and see how the car feels.
Old Jul 28, 2003 | 11:38 AM
Did you ever get in contact with DSS?
Old Jul 28, 2003 | 11:50 AM
H22Si's Avatar
The Hasport combo is the 90-93 Integra axles with a 90-93 Accord halfshaft.
I "hear" of some people having problems using this combo, the problem being that the passenger side Integra axle is .125" too short, causing leakage in some cases. The combo does work, but still you're trying to use factory pieces with a not-so factory setup so there will be problems.
Old Jul 28, 2003 | 12:05 PM
Default Re: Driveshaft Shop Axles Problem... (H22Si)
dangit...is there nothing to use with the Prelude halfshaft?
Old Jul 29, 2003 | 08:34 AM
H22Si's Avatar
Honestly, I'm not aware of any combo that works with the Prelude halfshaft.
That's my only complaint with this swap, the $$$ axles.
Old Jul 29, 2003 | 10:24 AM
mister2racer's Avatar
frank at DSS told me he has a setup that uses the prelude inner shaft and that he actually prefers that.
i have not yet purchased these from him yet. i am considering just getting the h22 rollin on the standard combo first.
i have his axles for my mr2 and they are great. A friend of mine in the mr2 community is uses his axles in his 615rwhp mr2 with no problems... then again my other friend is running 1.3 60's on his stock mr2 axles so whatever.
Old Jul 29, 2003 | 11:19 AM
Default Re: (mister2racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister2racer &raquo;</TD></TR><TR><TD CLASS="quote">frank at DSS told me he has a setup that uses the prelude inner shaft and that he actually prefers that.</TD></TR></TABLE>
That's the setup I have...but for whatever reason, I'm pretty sure my axles are too long.
Old Jul 29, 2003 | 04:35 PM
cccya's Avatar
Default Re: (Jonathan_EH)
i'm using DSS II and i love them! i'm also using the prelude halfshaft with them
the axles are great. no leaks or breaks....just as long as you have the accord forks to clear them.
BTW i'm using the place racing mounts.....
Old Jul 29, 2003 | 04:37 PM
poison's Avatar
Default Re: (cccya)
I'm using Level 1 passenger axle and Stage 1 driver axle using the lude midshaft, no issues at all. I've even beaten the hell out of them using slicks.
I'd call frank, he'll take care of you.
Old Jul 31, 2003 | 08:13 AM
Default Re: (poison)
Called Frank at DSS, and he said that I'm not putting them in far enough, and that's why they seem too long.
I was like yes I am, but I think he thinks I don't know how to install axles.
I measured the maximum depth the axles are physically capable of going in, and then measured that distance on the input shaft, and they match.
So I know the axles are as far in as they can go, so something just isn't right.
Old Jul 31, 2003 | 09:58 AM
SleeprCivic's Avatar
It sounds like grease from the boot if its around the outer side of the axle and on the wheel. Have you looked closely at the boot to see if it is ripped?
Otherwise, you took a rubber mallet and hit the axle until it clicked in right?
Old Jul 31, 2003 | 10:30 AM
Default Re: (SleeprCivic)
aren't you only supposed to bang in axles if you can hold them completely straight and square to the tranny? Something that's very hard to do with the Hasport kit without something getting in the way.
redcivic13
Feb 4, 2008 03:57 AM
builthatch
Oct 2, 2007 05:25 PM
Sketch_hs
Sep 22, 2003 08:46 PM
austrian type-R
Aug 6, 2003 01:07 AM
hioctane3
Apr 25, 2003 10:21 AM
