May need to replace clutch - few questions.
Old Jul 27, 2003 | 10:26 AM
type r 01-1063's Avatar
Default May need to replace clutch - few questions.
My clutch may be glazed. It requires for me to depress the clutch pedal 75% down for the clutch to engage/disengage. Shifting is stiff still also. I sure i can resurface the flywheel and purchase a new clutch set.
Am I able to get away from purchasing a whole new clutch set by just buying the clutch friction disc and resurfacing the pressure plate (pressure plate resurfacing possible?)?
Old Jul 27, 2003 | 02:54 PM
Default Re: May need to replace clutch - few questions. (type r 01-1063)
Bump
Old Jul 27, 2003 | 03:09 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 &raquo;</TD></TR><TR><TD CLASS="quote"> I sure i can resurface the flywheel and purchase a new clutch set.
... so do it.
Old Jul 27, 2003 | 05:47 PM
Default Re: May need to replace clutch - few questions. (Soup ****)
Sure I can do it but I was questioning another alternative
Old Jul 27, 2003 | 07:42 PM
vtec.dc2's Avatar
i'd buy another clutch instead of trying to patch up the existing one.. beware of bearings with aftermarket clutch kits - make sure everything match..
in my case, release bearing was too small and made all types of noises.. had to re-install with oem bearing - no problem after that
Old Jul 27, 2003 | 08:34 PM
Default Re: May need to replace clutch - few questions. (vtec.dc2)
Of course, I'd always stick with OEM bearings.
Old Jul 27, 2003 | 09:02 PM
SoCal ITR's Avatar
I don't think being glazed is the problem. Might be one of the bearings.
Y2ksi
Apr 7, 2005 07:55 PM
dr_latino999
Mar 13, 2005 08:55 PM
hondacivic_si
26
Mar 2, 2005 07:20 PM
dohcdelsol
14
Aug 16, 2004 10:42 AM
vaporboy12
Jan 6, 2004 06:57 PM
