a t3/t04e turbo will fit on a drag mani right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2916 »</TD></TR><TR><TD CLASS="quote">jsut making sure that a drag manifold will fit on a t3/t04e turbo</TD></TR></TABLE>
Yes it will but it also depends if it is a 5 bolt discharge or 4 bolt. If it is a 5 bolt it is a easy fit if it is a 4 bolt more hacking of your block is necessary or even a 2nd flange on the manifold, it sits closer to the left and to the block on the passenger side for 4 bolts. Also depends if you have a B18 motor or B16A motor whoch is 7mm shorter deck.
