DC got 0wNeD!
on me! well, i was driving in an unfamiliar area (known for its "bad luck") and ran over a parking curb... oh wells, I guess its that time for the SMSP i always wanted...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR »</TD></TR><TR><TD CLASS="quote">At least it's only a header. Good excuse for an upgrade.</TD></TR></TABLE>
that's true, i've seen worse header damage
Because there's a huge difference in the design, as well as the larger collector is a huge improvement. You won't see a good header, like smsp, dtr, header-tech, anr, etc... using a 2.25" or 2" collector, because it sucks.
with the usdm dc 4-1 and the tanabe rm, you're probably making maybe 5-8 useable hp....
The JDM 4-1 doesn't have the carb plate on the header, thats another way to tell. Take a look at mine....
Measure the diameter of the primaries on your header. Some of the DC USDM models are actually 1-3/4" just like the DC JDM. The USDM DC GSR header is also 1-3/4" tubes but the 2" USDM collector. All you need to do with those are cut the collector off and add a taper with a 2-1/2" outlet.
jisecup...the search button is your friend... dont ***** out someone else's thread
you will not be making 5-8 useable horsepowers from your usdm dc header and racing medallion if you are already driving a type R
...more like 3-5 hps
