my swap ou tthe shop
Old Jul 27, 2003 | 06:30 AM
shadowstylz's Avatar
Default my swap ou tthe shop
2 things wrong Im leakin oil from headgasket on the left hand side closest to you if your lookin in the engine bay...
not to pissed off about that since there gonna replace it free.
now Im concerend about this issue my motor doesnt get enough fuel they said since I got 175xxx on my fuel system its startin to act weird but they said more than likely if they up the fuel pressure everything will be fine. what do yall think? because my car is real sluggish in first I have no power till 4 then it starts to move... but other in that I feel slower than a dx in first and in all other gears if I floor it I can Feel that the motors not getting enough gas... so my question is do yall think it will be fine after we put the fuel pressure regulator on?
Old Jul 27, 2003 | 07:27 AM
Lil Red CRXsi's Avatar
Default Re: my swap ou tthe shop (shadowstylz)
Ok lot of things to think about here.
You just got a motor swap done and plan on it running good without a fuel upgrade.-a fuel regulator and a gauge would be a good start.
You might wan't to go with a better pump-a little more info on what you have done(the swap) would help.For example,A pump for a dx ain't going to run a B-16.it won't pump the volume needed on demand.-hence the bog.
s1ngleslam
Oct 21, 2008 12:37 AM
aeenox
36
Feb 14, 2008 02:19 PM
regal1975
12
Jun 13, 2006 08:16 AM
bossman032
13
May 15, 2004 03:48 PM
se93
Dec 25, 2003 01:47 PM
