need pics of b18b1 in EK haven't been able to find it on search.....
Old Jul 27, 2003 | 05:45 AM
GumballNA's Avatar
Default need pics of b18b1 in EK haven't been able to find it on search.....
like the heading says... i espcially need a close up pic to where i can see the driverside mount... cuz someone told me that i need SI driver sidemout... so i wanted to see what it looks like...
Old Jul 27, 2003 | 05:47 AM
VTECVillain's Avatar
Default Re: need pics of b18b1 in EK haven't been able to find it on search..... (Type-X)
You don't need the mount, you need the Si engine mount bracket - the part that bolts to the engine. You can reuse your stock mount on that bracket.
Old Jul 27, 2003 | 06:13 AM
GumballNA's Avatar
Default Re: need pics of b18b1 in EK haven't been able to find it on search..... (VTECVillain)
http://www.hondaautomotivepart...84%29
which number? im thinking it was like #25.....
Old Jul 27, 2003 | 08:58 AM
Trey's Avatar
25 Year Member
This is a GSR swap but they both use the same one.....
part number: 11910-P30-000
Old Jul 27, 2003 | 09:14 AM
GumballNA's Avatar
Default Re: need pics of b18b1 in EK haven't been able to find it on search..... (Trey)
ok so the GSR and the SI driver side mount are both the same? hey by the way is that ur motor? i like what u did with the car gear cover how u cut it out.. looks clean...
and i was told i need int. vibration mount? and si rear mount?
Old Jul 27, 2003 | 08:19 PM
Trey's Avatar
25 Year Member
No, I meant that the LS and GSR motors in an EK both use the 99-00 Si driverside mount bracket.
The pic above is a comparasion between the LS/ GSR vs the Si mount bracket.
I just cut the plastic with a jigsaw.
All the info you need for an EK swap is listed in my sig below.
Old Jul 28, 2003 | 04:02 AM
SupaDX's Avatar
well i was wondering what other mount's and brackets do you need except for the engine mount bracket? because i am doing the EXACT same thing.... except Type-X i had talked to you and i thought you were doing the GSR swap?
Old Jul 28, 2003 | 04:24 AM
GumballNA's Avatar
Default Re: need pics of b18b1 in EK haven't been able to find it on search..... (SupaDX)
as far as i was told.... u need the SI tranny bracket, and the SI engine bracket.... and that's it. and actually ya now i have decided to do the B18c1 swap.. it's more benefcial for me in the long run... but good luck bro on ur project.
-Jason....
p.s someone correct me if im wrong on the mounts...
Old Jul 28, 2003 | 06:06 AM
Trey's Avatar
25 Year Member
:sigh:
Doods, click this link and READ!
http://www.eddiesun.net/~trey/6gen/
Old Aug 3, 2003 | 03:24 PM
GumballNA's Avatar
does anybody else actually have pictures... of b18b1's in their EK/Ej's etc.
Old Aug 3, 2003 | 05:35 PM
Trey's Avatar
25 Year Member
It's the same mount.
Old Aug 3, 2003 | 06:04 PM
GumballNA's Avatar
dammit trey i know! hahaha, i just like to see people's ek's with the b18b's in them just cuz it looks purdy..haha
Old Aug 3, 2003 | 06:59 PM
Trey's Avatar
25 Year Member
Oh, I just thought you were hard headed.
I'll get my friend to post pics of his 96 EK b18b1 turbo for ya.
Old Aug 3, 2003 | 07:11 PM
Trey's Avatar
25 Year Member
Couldn't find any with the turbo but these might do..........
Old Aug 4, 2003 | 12:07 AM
MPower332TI's Avatar
Heres my B18b. Its purdy..haha
Old Aug 4, 2003 | 07:31 AM
GumballNA's Avatar
Default Re: need pics of b18b1 in EK haven't been able to find it on search..... (jDmDxTuRd)
thanx guys keep um comning.... hey on ur pic's trey... is there throttle cable bracket in place? cuz i don't see one?
Old Aug 6, 2003 | 07:48 AM
xpl0de's Avatar
how does it feel to have a b18b in a EK?
Old Aug 6, 2003 | 09:54 AM
DevinW's Avatar
Default Re: (xpl0de)
Here's my B20 swap...looks the same as an LS swap:
Old Aug 6, 2003 | 10:15 AM
GumballNA's Avatar
Default Re: (DevinW)
nice devin... just curious tho, how much did that complete swap cost u, i know u have to purchase the long-block seprate.. and then throw on a tranny, and axles. and all that fun ****! but how much did everythign cost, to make it run right
Old Aug 6, 2003 | 11:20 AM
DevinW's Avatar
Default Re: (Type-X)
Probably about the same as a full GSR swap, because I've got the 4.785 FD ITR tranny, ITR flywheel/clutch.
If you want to do a B20 swap....PLEASE save yourself the hassle and buy a complete LS swap first. Then either find a B20 short/long block and swap it in, or sleeve the LS to 84 mm.
I spent way too much on stupid gaskets, o-rings, bolts that were missing. I would not do this swap again unless I found a complete LS swap and then the B20 block.
Old Aug 6, 2003 | 11:36 AM
BI8B's Avatar
what tranny mount are you guys using? i dropped a LS motor in my car but i'm missing the front tranny mount. anyone know the part number?
Old Aug 6, 2003 | 12:02 PM
GumballNA's Avatar
Default Re: (BI8B)
ya thats what i figured devin, that it was too much hassle, ill probably just make my LS a b20... by boreing it and all the fun ****! WEE! lol
the front tranny mount ur missing? umm... im not completely sure ask them, i haven't got my b18b yet.
Old Aug 6, 2003 | 02:31 PM
GumballNA's Avatar
just wondering what ECU are u guy's running on ur EK's?
Old Aug 6, 2003 | 08:25 PM
DevinW's Avatar
Front transmission mount bracket from a 99-00 SiR. Use your stock civic bolt/stud and stock rubber frame mount.
I'm using an OBDI P75 ecu...just an LS ecu.
Old Aug 6, 2003 | 08:48 PM
BI8B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DevinW &raquo;</TD></TR><TR><TD CLASS="quote">Front transmission mount bracket from a 99-00 SiR. Use your stock civic bolt/stud and stock rubber frame mount.
I'm using an OBDI P75 ecu...just an LS ecu.</TD></TR></TABLE>
the bracket you're talking about...is it #10 in the pic?
